Best street suspension setup?
RE: Best street suspension setup?
ChiDiddy:
A Watts linkage wouldprobably not beyour best bang for the buck. There are a lot of other things you could do for less. Here are my suspension mods.
Manufacturer Description Part #
Eibach Springs - Pro Kit Mustant GT 35101.140
Ford Racing Mustang GT Damper Kit M18000A
Steeda Mustang - Adj Strut Tower Brace 555-2752
Steeda Mustang - G-Track Brace 555-5530
Steeda Mustang - Adj Front Sway Bar 1-3/8 555-1050
Steeda Mustang - Front Swaybar Mount Brace 555-5553
Steeda Mustang - Rear Sway Bar w/links 555-1052
Steeda Mustang - Adjustable Panhard Bar 555-2551
Steeda Mustang - Panhard Bar Brace 555-2555
Steeda Mustang - Adj Lower Trailing Arms 555-4416
Steeda Mustang - Tublar Upper 3rd Link 555-4105
BMR Bolt in Relocation Brackets CBA005
Hawk HP Plus Front Pads 164-HB484N.670
Hawk HP Plus Rear Pads 164-HB485N.656
Goodyear Eagle F1 GS-D3 VBS 255/45ZR18
Good Luck
Good Luck
www.cheperformance.com Check out all the different parts...
www.dynojoe.com. Call and speak with Joe. He'll help ya out with your suspension needs...
www.pmpparts.com Speak with Josh or Kevin on your suspension needs...
www.hotpart.com Pick up the Tokico's here. They are 507 out the door.
www.brenspeed.com Get your Ultralite's here....cheapest I've found so far.
i greatly appreciate the help guys!
yes, the watts link idea is scraped.
i'll be going this route now:
-D-SPecs
-Steeda Ultralites
-BMR Adj. PB + brace (tie rod or poly version??)
-BMR Adj. LCA tie rod/poly combo
-BMR non-adj. 3rd upper link (poly) + mount
-BMR rear sway
-18's-19's + General Exclaim UHP tires
-Stoptech BBK 2-piece rotors + Axxis Ultimates +Motul Dot4
this is will be the first part of the suspension upgrades that i will be doing for now. Any input on the poly vs. tie rod parts above would greatly help.
also, the LCA relocation bracket would greatly help my goal for drag racing + boost, but i'm unsure on how to align the instant center angles myself....
-D-SPecs
-Steeda Ultralites
-BMR rear sway
thanks for the heads up! i'll see about it some CHE parts, but i usually like to stick to one brand as much as possible. Cost really isnt a factor to me.
also, i based my list off CrazyAl's advice.
I'll concur if you can afford it go withSaleen Watts Link I did.
You can also go fay2 or lakewood wattsfor less money.
Me coming from a 350zI missed the independent rear supension.
The watts linkmade the car track and feel better plus it replaces the pan hard bar (not needed any more).
You cant go wrong with Toiko adjustables I did all the prototypeing for the 350z (the car handled great).
My supension is mostlyall Saleen shocks+ sway barsbut hated the ride height so I changed to eibach sportlines and love em (they worked well at Willow Springs).
Dseid2,
I see your suspension setup is close to what I am shooting for. I have the Steeda Sports, ProAction dampers, Panhard bar and brace. I love what it has done for the car, but think I need just a little more flattening and a little more neutral handling. I am considering the Steeda F/R sway bars.
What are your impressions of these. Any significant depreciation of the ride quality or NVH with these components?
Any impressions or inputs welcome?
