what 20 inch tires for 06 stang front/rear with sportline kit so it wont rub
RE: what 20 inch tires for 06 stang front/rear with sportline kit so it wont rub
I have 265/30/20 and 285/30/20 in the back. In hindsight I would have gone 35 series tires all they way around. Some tire manufacturer's wont go bigger than 30 series for 20's in the rear when the tire width gets real wide (like 295 on up). I could be wrong but check with our sponsors like Tirerack.
Oh and a caster camber kit for the front and and ADJ panhard bar for the rear to center the fat rear tires.
does is rub at all in the back,bcuz i a full stero system in trunk also should i keep sportline or switch to prokit and did also change shocks out,holla back!
No rubbing in the back and the springs should handle the weight of the stereo system. If you take a large bump at a decent speed you might bottom out but just try not to do that. If you are lowered many recommend getting the Tokico D-specs as they are adj for a soft or stiffer ride and make the best of the lowering springs. You should be fine with the springs you have now.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
