Need Help With Front End Suspension!
Old Aug 25, 2007 | 08:39 PM
Denny Carlton's Avatar
Denny Carlton
Default Need Help With Front End Suspension!
Hello, Folks!
It's me again. I'm looking to make my front suspension match my rear.
First of all, I have the D-spec shocks on my list.
What else can I do to make the oversteering go away in the front of the car?
Do you think I should get the GT front sway bar to match the rear bar that I have already?[/align] [/align] Thanks for any help![/align]
Old Aug 25, 2007 | 08:43 PM
jrherald420's Avatar
jrherald420
Default RE: Need Help With Front End Suspension!
just spend a little more and buy a bigger one !!! stock would be fine but bigger is better.
Old Aug 30, 2007 | 01:40 AM
DelStang86's Avatar
DelStang86
hellwigs ftw.
Old Aug 30, 2007 | 11:58 AM
billybix76's Avatar
billybix76
+1 on the Hellwig's...Yep Get em both. oversteer will become neutral. Do you have Poly aftermarket LCA's? they also help reduce Oversteer. basically anything yo can do to the rear to stiffen it will cause the front to track better and vice versa....
Old Aug 30, 2007 | 09:40 PM
4Rowdy's Avatar
4Rowdy
"GT front sway bar to match the rear bar"--- YES
Before I swapped the front sway, the steering was really sloppy. I have a bad habit of resting my knee on the bottom of the steering wheel to steer on straightaways. Before the GT sway on the front, there was no way I could do that, it was all over the road. Once I changed to the GT, not a problem. Nice and tight now.
Old Aug 30, 2007 | 10:01 PM
Denny Carlton
The Gt front sway bar will be next on my long list of mustang mods. Thanks K,
Old Sep 25, 2007 | 01:34 PM
Sevalley's Avatar
Sevalley
how much does installation of the dpsec shocks/struts cost? I see the front and rear combo available on ebay for about $500, but I am afraid that installation will run me another $500. Anyone have any idea? I didn't find the front GT sway bar to make a big difference. It was the rear GT sway install that made the huge difference.
Old Oct 4, 2007 | 03:23 PM
oshkoshbajawsh's Avatar
oshkoshbajawsh
I ♥ Acer
sevalley, call midas.. i hate to say it but they can install that stuff for pretty cheap(should be way under 500)
Old Oct 30, 2007 | 08:52 PM
oi8achevy's Avatar
oi8achevy
larger antisway bars will give you a big performance gain. dont forget it all means nothing if you dont have serious tires.
GimpyHSHS
Sep 18, 2015 12:27 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
