Rear drop
Old Dec 7, 2007 | 11:21 PM
smythge's Avatar
smythge
Default Rear drop
I'm looking at lowering the rear of my car with Roush Springs, wondering if anything else is required? Any help is appreciated.
Old Dec 8, 2007 | 11:24 AM
Aziraphale's Avatar
Aziraphale
Default RE: Rear drop
Technically, no, nothing else is required. Many people like to replace the springs, do lower control arm relocation brackets, new lower control arms to adjust the pinion angle, etc. If you're just going for the look and not maximum traction, just lower the rear with the springs and move on with life. If you're building a drag car, replace the rest.
Old Dec 8, 2007 | 09:10 PM
smythge's Avatar
smythge
ORIGINAL: Aziraphale
I would like to improve looks, butnot at the expense of driveline wear and I don't want to cause other problems. By lowering the rearend 1" how much will that change the pinion angle? Any other problems I may encounter?
Old Dec 9, 2007 | 06:55 AM
Boss919's Avatar
Boss919
I think you will be fine. i installed Eibach Pro's and with 1.25 drop the pinion angle adjustment was minimal. If you are unsure just by a magnetic angle finder gauge and check it.
Old Dec 9, 2007 | 09:41 AM
ziperhead's Avatar
ziperhead
I lowered the rear with Roush and my car looks great but rides somewhat bouncy although not unbearable. Not real sure of the center was off before or after the springs were installed but the car is off 1/2 inch. I plan on installing a adjustable panhard bar to correct
Old Dec 9, 2007 | 01:33 PM
Stoenr's Avatar
Stoenr
Well said, I would have to agree.
I had the rears only installed for a year. Then put some adj LCA's and adj panhard because I came across a good deal.
Old Dec 10, 2007 | 12:38 AM
GT Bob's Avatar
GT Bob
Just installed these not too long ago.Pinion angle was within limits and my center was off by slightly more than 1/8", tho a the start, it was off by an 1/8" the other way..
Old Dec 11, 2007 | 11:58 AM
smythge's Avatar
smythge
Sounds good, I just ordered the rear springs, I'll check the pinion angle before and after and report back.
67LimeCoupe
Sep 30, 2015 04:46 PM
musnicki
Sep 23, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Sep 8, 2015 11:50 AM
zanemoseley
Sep 6, 2015 12:58 PM
