Drag radials
Old Jan 12, 2008 | 04:05 PM
matswpa844's Avatar
matswpa844
Default Drag radials
I have a 2006 Gt with the stock 18" wheels. Im looking for a drag radials the tire size on the car now is 235/50/18.
I cant find any such drag radial.
thanks for your help
Mark
[IMG]local://upfiles/47228/6050F1AE8114417A99B3E7E24F761345.jpg[/IMG]
Old Jan 12, 2008 | 07:08 PM
Blackhawk's Avatar
Blackhawk
Default RE: Drag radials
With an 18" rims there's quite a few options, but they are all wide tires to be used on 9.5-10" rims.
The only one that I know of out of all the larger manufacturers(Toyo, Nitto, BFG, M&H, M/T) is the Toyo RA1. And it's mmore of a autocross/racing tire. Surely the lower tread depth and sticky compound is better than a street tire, but it's no drag radial. I believe the size they offer is a 255/45-18.
good luck.
Old Jan 12, 2008 | 08:48 PM
reeflover's Avatar
reeflover
Yeah, Thats why I bought a wider rim for the rear.Nobody offers them for the stock 18x8 wide rims.
[IMG]local://upfiles/75574/BE9353FC72F44C92889281CA06E11830.jpg[/IMG]
Old Jan 13, 2008 | 08:32 AM
Bulitt's Avatar
Bulitt
Get 10 inch rims with the nitto 305/35/18 traction problem solved
Old Jan 18, 2008 | 06:37 PM
matswpa844's Avatar
matswpa844
Thanks for your help. But this is what I did I bought 2 stock take offs 17".Now what kind of Drag radials should I put on them?
Thanks 4 ur help
Mark
[IMG]local://upfiles/47228/AFEDFD72A71C4599A15A598EE8862181.jpg[/IMG]
Old Jan 18, 2008 | 11:45 PM
Simon1's Avatar
Simon1
BFG will make one that can fit your tire. Search around on their website you will be okay.
Also the ET streets will work. I saw a guy at the track using the stock 17's with 275/55/17 tires and he got 1.7xx 60's.
Old Jan 18, 2008 | 11:50 PM
Simon1's Avatar
Simon1
Try this
http://www.mickeythompsontires.com/s...ETStreetRadial
Old Jan 23, 2008 | 06:11 PM
black S197's Avatar
black S197
Check out Breenspeed's package. http://www.brenspeed.com/mustang_2005/wheels.html
2 OEM Ford Wheels & 2 Mickey Thompson ET Street Racing Tires
Here is the Brenspeed tire combo. We run this same style! Two factory wheels with a set of cheater slicks. If you want to go fast at the track these tires will put the power to the ground.
$629.99
Old Jan 23, 2008 | 10:01 PM
matswpa844's Avatar
matswpa844
Thanks 4 the info ...I just got my new 17" take offs today and i orderd a set of M-H Drag radials 275/50r70 should have them next week.
Mark
[IMG]local://upfiles/47228/86F7A8E99135487DB9A6899EFD6F3358.jpg[/IMG]
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 15, 2015 07:34 PM
vintageaion
Sep 8, 2015 10:45 AM
