Traction Problem. Need some help!!!
Old Feb 2, 2008 | 08:05 AM
flounderlipps's Avatar
flounderlipps
Default RE: Traction Problem. Need some help!!!
Check you air pressure, make shure it is the same in both your rear tires. You cango about 1 or 2 psi lower in yourdriver side rear. Because these cars hook a little to the right when you hammer it from a stop.
Youcan take the pressure down to about 28 or 30 psi.
Old Feb 2, 2008 | 10:49 AM
ErcWrestlr's Avatar
ErcWrestlr
Its the weather. I run these same tires at 30 psi in the front and 35 psi in the back for daily driving. I never have an issue with traction. I am also never in temps under 60 degrees though.
Old Feb 2, 2008 | 12:41 PM
Sleeper_08's Avatar
Sleeper_08
"I am also never in temps under 60 degrees though. "- must be nice as I look out of my window watching them clean up after a big snow storm!
Old Feb 3, 2008 | 03:59 AM
exx1976's Avatar
exx1976
^^ +1
I cleaned off my winter beater this morning.. Had an inch of ice on it, then 4 inches of snow on top of that...
Old Feb 3, 2008 | 08:37 AM
jdmcbride's Avatar
jdmcbride
ORIGINAL: wakebord99
It's possible that the tempurate difference effects nitrogren more than air. For example: My car's tire presure in the morning (35 deg.) is around 24, and by the time i'm done with my 1 hr commute its at 31 psi with air. It's possible that Nitrogren cold is at 31 psi, but expands to 36, or even 40 when it's warm.
Actually, pure nitrogen is better than air (80% nitrogen, 18% Oxygen, 2% Other) in that it is not affected as much by temperature differences. It is the oxygen molecule that expands and contracts with higher and lower temperatures. That is why all aircraft, NASCAR, and NASA's shuttle fleet use nitrogen in their tires. So you will maintain a more constant pressure over various temperatures.
Another reason nitrogen is used is that the nitrogen molecule has a larger diameter than the oxygen molecule and takes longer to work its way out of a tire. So you will maintain your pressure longer than with air. This is how the nitrogen dealers can say that nitrogen in your tires will get you better MPG.
iluvmycar - Your summer tires in cold weather = loss of traction. A good UCA and LCAs could help keep your tires maintain better contact with the road and help a little bit. But warmer weater will help a lot!
Old Feb 3, 2008 | 11:53 AM
Sleeper_08's Avatar
Sleeper_08
Does any know whatminimum temperature range is suggested for the BFG KDW2's to give me some idea of when I will need to switch to the rims with the Blizzaks or equivalent.
My car is going to be a DD, except when it snows I'll either work from home or take public transit.
Old Feb 3, 2008 | 11:59 AM
UrS4's Avatar
UrS4
Sleeper_08,
Tire rack recommends changing to winter tires when the temps fall below 45 degrees.
Old Feb 3, 2008 | 12:04 PM
brian06eleanor's Avatar
brian06eleanor
ORIGINAL: Sleeper_08
the kdw2s are considered a all weather tire. they will do decent in any weather. as for the thread startee, dont feel bad about the traction. everyone has that prob when it gets colder. if my tires are cold and the roads cold then i can fishtail 2 lanes from a 60 roll in 3rd!. just heat your tires up and they will grip a little better.
Old Feb 3, 2008 | 07:49 PM
Sleeper_08's Avatar
Sleeper_08
UrS4
Thanks.
For us Canadians that translates to7 C whichmeans I can use them for at least 7 months of the year.
ChampInSD
Oct 2, 2015 04:55 AM
69Volunteer
Sep 30, 2015 10:39 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sep 8, 2015 11:50 AM
iculookin
Sep 2, 2015 12:34 PM
