Steeda Rear Sway Bar Worth It??
RE: Steeda Rear Sway Bar Worth It??
that was the first suspension mod i got it helped stop understeering the dam car. i would get it. but now with my relocation brackets for the control arms. it always rubs up against the sway bar and makes an anoying sound goin into driveways.
You would notice a difference but they are still pretty small compared to the size of the car so flex will still happen. To me springs and good tires are money better spent or a thicker sway bar.
ORIGINAL: greg94
would it have a positive effect on a 06 saleen, as saleenincreased the
front sway bar and keep the factory gt rear bar. this would be for a daily driver.
If they increased the rear spring rates by a significantly greater percentage than they did the fronts and you're happy with how it behaves now, I wouldn't bother.
If it still 'pushes' a little too much, a larger rear bar will usually help. Just keep in mind that a little diameter increase goes a long way.
If the tail is currently trying to step out on you or run wide of the nose in only moderate driving, don't even consider doing this.
Norm
09-08-2015 11:50 AM
09-02-2015 08:40 PM
