burn-outs
Old Mar 21, 2008 | 12:04 PM
shooter23's Avatar
shooter23
Default RE: burn-outs
FIrst off, if your going to the right, it would be due to the fact that mustangs come from factory with their rear-end uncentered. So an adj panhard bar would help this to re-centre, but it wont be 100% becuase of the differential we have...but it def will help.
As for the wheel hop, get your self a set of lower control arms. The relocation brackets are not NECESSARY, but I would suggest them. I did a bunch of rear suspension work; adj pHB, LCA, UCA, relocation backets, etc, etc and now, it burns the tires straight and the wheel hop is gone...I am VERY happy with the rear-end now.
Lemme know if you need anthing else!
Old Mar 22, 2008 | 06:02 PM
jerrym's Avatar
jerrym
preciate the advice - and so the mod to do list grows lol
Old Mar 23, 2008 | 08:51 AM
Norm Peterson's Avatar
Norm Peterson
ORIGINAL: jerrym
Whenever l do a burn-ot, the rear end always slides over to the right! What do l need to correct this to a straight line and stop the sometimes wheel-hop? also.... what is the largest-safest tire to mount on my stock 18 x 8.5 fanblades?
LCAs with stiffer bushings (poly)or poly/rod end LCAs.
For 18 x 8.5, 255/45's are the limit as far as tire mfr/Tire & Rim Associationacceptability goes, and in cases like thiswhere rear end tracking is already a problem I wouldn't want to give up lateral stability (read: ease in catching it when it does step out) by going any wider on the tire than what's approved.
Norm
Jarrod@latemodel
LatemodelRestoration.com
Apr 18, 2012 02:21 PM
ponyman
Mar 9, 2012 11:36 PM
Jackies Stang
Sep 8, 2007 06:30 PM
SonicStanGirl
Aug 14, 2006 08:24 PM
