lca
Old Apr 2, 2008 | 06:20 PM
F1Fan's Avatar
F1Fan
Default RE: lca
ORIGINAL: Norm Peterson
ORIGINAL: Dex
The GT500 LCA's look the exact same as ours. I'll get some pics up tonight. Dont waste your money and go buy BMR, Steeda, or CHE
It isn't what the arms visually look like at a casual glance that matters when it comes to axle control. The important thing is bushing stiffness, and that's not something you can tell just by looking at them. The difference is that the SVT arm use bushings (FRPP catalog, PN M-5649-R, page 47) that are higher Durometer, or stiffer than the standard LCA bushings. Bushing stiffness is what locates the axle more precisely, and is what's mostly responsible for thequieting down of cases of wheel hop when you upgrade the LCAs and UCA.
Chip has provided a lot of good information in a small package. But I can add a little. One of the reasons that the FRPP bushings are slightly softer is because too stiff will start to twist the LCAs themselves, which is not the hot tip for loading a sheetmetal stamping. It's still an upgrade, however.
Conventional poly bushings work fairly well for a street/strip car that isn't cornered very hard, and that's about what those things should be limited to. In hard cornering, they work against careful suspension tuning, or at least force compromises in it. Bushing bind in roll is a topic that's been extensively discussed elsewhere, and I've done a little "one-off" tinkering of my own on this (Chip: think voided bushings). Let's just say that the effect of out-of-the-box plain poly bushings can be as great as adding a medium-sized rear sta-bar where there was no bar before - or doubling up on the one that is there.There is an associatedride quality effect that is clearly noticeable even during mild/moderate driving over certain road conditions. The S197 may be a little better off in this respect than the Fox/SN95 for which there is some actual aftermarket test data available, but the effect is still there.
What I'm getting at is that there is more to rear LCAs and their bushings than first meets the eye. Again, they're generally fine in street/strip cars that don't ever see hard cornering. But they are not "universal solutions" for all rear axle location issues, notby any stretch of the imagination.
Norm
Hi Norm!
Exactly! With the GT500 LCA's the importantpart is in the design of thebushing durometer and the high misalignment capability of this type of joint with reasonable bushing durometers. You will also note that the bushing design is directional. That is to say the bushing is designedto locate the axle morepositively along the LCA's long axis which is the only direction that loads are designed to be introduced to this suspension component. The bushings are more free to move vertically and around the perpendicular axis of the bushing joint due to voids in the bushing material and these voids also serve to reduce NVH at the same time.
As you know the real limitations of a solid or conventional constrained poly bushing are largely due to limited freedom of movement. When these limits are passed or stretched they can cause artifically induced and unanticipated increases inrolland/or spring rate. These same poly bushings also tend to fail if they are elongated much past a few percent which is why you have to inspect and replace the things so often.
A voided polybushing isexactly where I was goingwith this and I have posted lengthy descriptions on this idea here and in other forums. There are some interesting possibilites in the market for this type of joint and I'm pretty sure they could havethe samelifetimeof ahigh-end 3-piece/lined rod end with much better NVH and practically the same level of location compliance.
Have you seen or are youfamilar with the Currie Johnny Joints? They are fabulousjoints witha long streetlife,verylow NVH and very good compliance. They are also reasonably strong and easy to buy from a pretty good company. Off roaders have been using these things for years. Thatis actually where I first encounteredthem and I was amazed at the abuse they took over and over for years on everything from these tiny lightweight articulated suspension4x4 rigswith these blown V8 monster motors toIMOTFB 4x4's with veryhigh mass and even bigger motors than the articulated 4x4 contraptions. They seem towork pretty well under grueling conditions and can tolerateamazing levels of misalignment. I like'em! Look at this LINK!
Cheers/Chip
Old Apr 2, 2008 | 06:23 PM
F1Fan's Avatar
F1Fan
Default RE: lca
ORIGINAL: Dex
Hi Dex,
Don't bother, we all know what GT500 LCA's look like and as you say they appear similar. But that is not the real story. Read Norm's post.
HTH!
Old Apr 2, 2008 | 07:42 PM
RodeoFlyer's Avatar
RodeoFlyer
Default RE: lca
MM's with rod ends at both ends FTMFW! [sm=gears.gif]
I have the UMI/Strano swaybar endlinks. Well made.
Seriously - we have lovely sounding V8's and at the very least 500W stereos. The whole NVH thing is blown WAAAY out of proportion. With a live axle hopping around on bumps anyway you're not gonna feel any more from the rod ends.
Quiet, supple rides are for minivans!!
Old Apr 2, 2008 | 08:00 PM
Norm Peterson's Avatar
Norm Peterson
Default RE: lca
ORIGINAL: F1Fan
Cheers/Chip
Yes, I've been aware of Johnny joints for a while, and I suspect it's what the "polyball" was modeled after. Mark Savitske at scandc.com carries the Johnny joints and is locatedreasonably locally to me. Given that his "skunkworks" has put together at least one upper class (possibly unlimited) Silver State Challenge car and developed a bolt-on C5-based front suspension upgrade for GM G-body cars, that he's carried them for a number of years at this point makes for a pretty strong and thoughtful recommendation.
I've spent some time trying to understand the whole business of compliant bushings, and it ultimately comes down to the fact that of the six degrees of freedom at each pivot, you really only want high stiffness in at most the threeforce directions or else the control arm is going to induce some amounts of roll and ride stiffnesses (and beat up on the control arms a bit if you're just plugging them into your OE open-section arms). For cornering, anyway. In drag racing, there might be some advantage in having induced effects - anything that opposes squat either by stiffening against it or damps the squatting motion is likely to be beneficial. Since the straightline business is arguably the bigger side of the performance market, that's my guess as to why that's about all that's been out there.
Anyway, there's a significantly modified set of ordinary poly in the LCAs in the thumbnail car. OK last I checked, though it was starting to wheel hop again at the starting line at auto-X so I think there's still a durability penalty involved. You could clearly feel the before/after difference in lateral head-toss going over shallow drainageways at an angle. I imagine that you've come across the results of the MM bushing bind study done some years back. I'm semi-educatedly guessing that an 80% reduction in their poly/poly numbers is easily achievable by careful voiding, putting you barely stiffer than OE in roll.
Voided poly might not get quite as good or be quite as durable as a rod/poly arrangement, but might be an acceptable low-buck alternative for those less fussy about bind-free kinematics or are more severely budget-limited.
I still have to crawl underneath my car, but that won't be happening this weekend.
[IMG]local://upfiles/62186/791801AD50C74571BCF31337B0B0632E.jpg[/IMG]
This maybe shows it better
[IMG]local://upfiles/62186/D4FB0A8D37814696975D8EC5D46B168E.jpg[/IMG]
Norm
Old Apr 2, 2008 | 08:13 PM
2007GT/CS's Avatar
2007GT/CS
Default RE: lca
ORIGINAL: RodeoFlyer
+1
Old Apr 2, 2008 | 08:27 PM
Norm Peterson
Default RE: lca
Thought it was you that Sam was referring to.
NVH? . . . nah, just the N when you're driving around on the street. Suspension 'clanks' are even worse than me when it comes to keeping a beat.
Norm
Old Apr 2, 2008 | 10:01 PM
F1Fan's Avatar
F1Fan
Default RE: lca
Hi RF!
Well personally I likenice quiet cars withmoderateride motionswithgood body control, sensitive steeringand reliable, predicable limit handling with a reasonable power to weight ratio. It must be all those years of driving911's or something. NVH? What good does that do anyone?
But having said thatI do love the almost brutal feel and feedbackthat my S197GThas compared to the smooth machine like German sports and GT street cars I've grown up driving.It sort of makes me think you could be right. 8^)
HTH!
Old Apr 9, 2008 | 03:27 PM
docwine's Avatar
docwine
Default RE: lca
I have the very LCA's he is showing above from UMI (from Strano) and love them. They are strong and don't bind or convey too much NVH.
Old Apr 9, 2008 | 06:37 PM
F1Fan's Avatar
F1Fan
Default RE: lca
ORIGINAL: docwine
Hi docwine,
I've got a pair of Steeda RaceDouble Adjustable LCA's in my car withSteeda poly bushings on the chassis side of the LCA and3-piece Teflon lined rod-ends installed on the axleside of the LCA. I've also got a pair of Aurora's mil. spec 4340Teflon lined rod-endsfor whenthe Steeda supplied rod-endsstart to wear.These LCA'scost a bit more than the single adjustable UMI shown but these are double adjustable like the UMI LCA'sSam sells for $220. Oh wait a minute,that's the same price asthe Steeda50/50 double adjustable LCA's cost! Of course the Steeda double adjustable LCA's usechrome-moly tubing and are cad plated so you can see right down to the welds instead of the heavily powder coated mild steel DOM UMI uses.But I agreethat QA1 ends are some of the better rod-ends available buttheyall wear out sooner or later.
HTH!
Old Apr 10, 2008 | 11:00 PM
sd07gt's Avatar
sd07gt
Default RE: lca
check out edelbrock's LCA @ UCA .... they are using Johny joints.. or a copy of them ! ....
