D-spec strut anomaly
Old Apr 21, 2008 | 08:10 PM
07BOSSGT_S197's Avatar
07BOSSGT_S197
Default D-spec strut anomaly
ok this has been kind of an annoyance, but not much of one to warrant ripping the front end apart.
The top center nuts that secure the D-specs to the Steeda HD strut mounts keep working their way loose. And they only do it when I have it dialed out for looser handling and when under heavy boost. My only thought is that the strut mounts themselves aren't secured correctly and allow too much play in the strut travel when the front end rises up and puts more tension on the front end.
P.S. I was told that I should be oiling the steeda bumpsteer...is this true? If so...oh damn I'm delinquent.
Old Apr 21, 2008 | 08:21 PM
Stoenr's Avatar
Stoenr
Default RE: D-spec strut anomaly
Id like to know if there is any routine maint. on the bump steer myself.
Old Apr 22, 2008 | 12:46 AM
Simon1's Avatar
Simon1
I would try some lock tite. Seems very strange. After 5000 miles and multiple adjustments mine, have always stayed tight.
Old Apr 22, 2008 | 07:26 AM
Argonaut's Avatar
Argonaut
Mine has been staying tight also, but I don't have the HP you do and thus the 'lift' of the front end. I do routinely change the settings all the way from 2 (hard) to 6 (soft). How many turns are are you setting them when this happens? Max is 7.5 according to the D-Spec manual.
Old Apr 22, 2008 | 01:45 PM
07BOSSGT_S197
ORIGINAL: Argonaut
I don't go any higher than 4-5 or any lower than 2 for the front.
baddog671
Jul 26, 2016 01:20 PM
67STANGX2
Sep 24, 2015 12:29 PM
allenmaty
Sep 24, 2015 09:17 AM
