Steeda Relocation Brackets
Old May 19, 2008 | 12:09 PM
07 S197's Avatar
07 S197
Default RE: Steeda Relocation Brackets
ORIGINAL: F1Fan
ORIGINAL: 07 S197
ORIGINAL: ziperhead
Why does the directions say not recommended for stock LCA's and if used use the lowest setting ? Doesn't make sense to me
because they wont fit. There was a mustang in at the dealership the other day that was useing the steeda brackets with the stock lca and it did not fit in them to line up with the holes. So he had to grind the back of the lca's to fit in the pocket
Ho 07S197,
That's weird, they looked likethey fit finewhen I've worked on cars with Steeda LCA brackets. Of course most of these carshad Steeda adjustable LCA'swith poly or rod ends or theSteeda billet LCA's but the space between the rear of the brakets looked thesame as the stock bracket gap. Maybe the LCA's yousaw were installed incorrectly? Steeda technical support has alsotold me that stock LCA's mechanically fit in any positionon the Steeda LCA bracketsandquestionedwhy anybody wouldwant torun stock LCA's in the stock locationafter going to all the trouble of installing them. I have to agree with Steeda technical support on thisas mechanically they look like they will clear the LCA brackets no problem. Why would you run a stock LCAin any otheradjustment location but the best one for your applicationroad course work or drag racing?
HTH!
the guy road raced the car, he said if he ran a aftermarket LCA that it would put him in a different class. The LCA's were the stock ones never removed so they couldnt ave been installed improperly. I saw it and they just wouldnt fit in there...
Old May 19, 2008 | 02:49 PM
F1Fan's Avatar
F1Fan
ORIGINAL: 07 S197
ORIGINAL: F1Fan
ORIGINAL: 07 S197
ORIGINAL: ziperhead
Ho 07S197,
HTH!
Hi 07S197,
I meant maybe the Steeda LCA relocation brackets were installed incorrectly. Are you sure they were Steeda LCA relocation brackets? The Steeda LCA brackets have 5 holes no the usual 3 or 2 as the other brandshave.
HTH!
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 24, 2015 09:18 PM
