Oil Starvation From High Cornering G Forces
While we were doing the install of the suspension upgrades one of the fellows asked if I was concerned about oil starvation fromthe high G forces the car would now be capable of reaching during cornering.
I've done a search of the forums and can't find anything related to this so was wondering if this is a problem.
Thanks.
Thanks.
RE: Oil Starvation From High Cornering G Forces
I've heard pros and cons about the stock oil pan and it's performance. Bottom line is, there's room for improvement. There are a few pans out there for the 4.6, but they're pretty much "generic" performance pans, if you will, with a little more capacity and some improved baffling, etc. Right now I'm in the process of developing a pan specifically designed for the S197 that will incorporate as much of the best wet sump tech. that can be used within the confines of the stock chassis. The fact that the engine is a Y block design limits things a little, as well, but the pan will have the right baffling, trap doors, and sump design (windage protection) to maintain good oil pressure and also free up some HP. I should have the prototype ready in a couple weeks for some testing, and if all's well, it should be available soon after that.
You might want to try posting your question on www.corner-carvers.com - if anyone knows those guys do.
Yes, that's definatly a problem. Stock pans are just that, a pan. They don't do much of anything to retain oil around the pick up.
Although not a mod motor, I use a fully baffled pan and an Accusump.
no problems here after 2 years of tracking with 2 drivers.
an accusump isn't a bad idea since it can be removed in a hurry. a big Canton oil pan isn't what you want a dealer tech staring at when you hurt the motor and take it in for warranty work.
ORIGINAL: .boB
[IMG]local://upfiles/96090/C90B8A8598864FD2B75B00B68153B5D1.jpg[/IMG]
ORIGINAL: steelcomp
On the last V8 I built I paid a good bit of attention to removing casting flash, deburring, and radiusing every oil drainback hole I could find in the block and heads.
Norm
