Suspension
Old May 21, 2008 | 08:07 PM
hecktic33gt's Avatar
hecktic33gt
Default Suspension
I'm looking at lowering my car. I'm looking for a clean drop thats not gonna make my car ride like poo. What do we need to lower it? Lowering springs, shocks and struts, bushings? And how much money am i looking at to install and buy everything. Thanks =)
Old May 21, 2008 | 08:17 PM
Argonaut's Avatar
Argonaut
Default RE: Suspension
Couple things:
- This question has been asked many, many times. You can go backwards in the posts and see the answers. You can go to the 4.6 Handling Section and see the answers. The answers are always the same:
- Cheap way - $200 bucks for lowering springs
- Right way - springs, Tokico D-Specs or Koni Sports, Adj PHB, camber adjusters - ~$900
- Extras that you might want/need depending on your particular car and goals: UCA, LCAs, reloc brackets, strut mounts, replacement bolts, etc.
Either of the above (cheap way or right way)will significantly change the behavior of the car, even springs alone you will likely interpret as a big upgrade (most do) but the full package is even better.
Old May 22, 2008 | 10:00 AM
BMRFabricationSales's Avatar
BMRFabricationSales
Former Sponsor
hecktic33, the best way to do it is going to be springs, adj panhard, lower control arms,cab relocation brackets, and a set of tokico d specs. If you decide to just go with springs make sure that you get an adjustable panhard to correctbody alignment. You will also need to check your pinion angle to see if it has changed.Here are a couple links to the parts that you will need. If you have any further questions please contact me.
http://www.bmrfabrication.com/2005MustangSUSPENSION.htm
http://www.bmrfabrication.com/2005MustangDRIVELINE.htm
Old May 22, 2008 | 03:28 PM
ScottsIre's Avatar
ScottsIre
Sure, you can spend over $1500 in suspension parts and labor for a road racing, handling dream car.. which would be nice, I'd admit. But my Eibach Pro-Kit gave me a nice, clean drop.. improved the handling and the ride stayed nice and smooth. I'm sure I'll replace the shocks & struts in a year or two, but it wasn't necessary to do so with just the Pro-Kit. Drives great for what I wanted and had available to spend.
(sig pic, pre-drop)
Old May 22, 2008 | 04:37 PM
MustangBatman1's Avatar
MustangBatman1
I would just do springs and d-specs for now, then add other parts later but I think those are the two most important parts speaking from experience anyway
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
