Titan up!
Old Jun 13, 2008 | 08:23 PM
dschmink's Avatar
dschmink
Default Titan up!
I've got the dampers and springs. Aside from a caster/camber kit what do I need to tighten up the front?
Old Jun 13, 2008 | 08:45 PM
2007GT/CS's Avatar
2007GT/CS
Default RE: Titan up!
If you are looking for some additional incremental improvement:
[ul][*]Adjustable swaybar endlinks[*]Spherical bearing strut mount/caster/camber plates[*]Aftermarket A-Arms/Bushings[/ul]
Old Jun 13, 2008 | 09:21 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
The only thing left on your 'to do' list is a completeGriggs GR-40 SLA suspension system [sm=tongue.gif]
(sorry, just had to pimp MY ride [8D])
..... as you were
Old Jun 14, 2008 | 07:02 AM
Argonaut's Avatar
Argonaut
What do you mean "tighten" up the front...what specifically is the issue?
Your rubber isn't exactly sticky (I have a set of Sumitomos), extreme perf summer tires make a big diff, at the cost of low treadwear. Also the alignment (I'm guessing you have understeer), more negative camber really makes the front end stick.
blackGTcp
Feb 21, 2008 11:37 AM
Bulldog66
Jan 5, 2007 11:37 AM
MustangGT3420
Jun 15, 2005 06:16 PM
