LCAs Clunking???
Old Oct 3, 2008 | 06:10 PM
  #31
mcstang's Avatar
mcstang
Default I was just going to order bmr adjustables
I have Eibach Pro Kit Springs and was told I should get the adjustable lca's. I'm glad I read this...should I forget it for now or can I use the Gt500's (hadn't considered that)? I can't stand the wheel hop.
Old Oct 5, 2008 | 06:47 AM
  #32
doc stang's Avatar
doc stang
Default bump for a few answers to the red questions
take to top
Originally Posted by doc stang
i have the BMR combination LCAs, with the poly-end forward on the car, and the rod-ends rearward on the axle.
?1) does anyone have the exact nut/bolt/ washer specs/sizes i need to do this?
i want to make only one trip to the hardware store.
?2) which type/color of loctite??
I also have the BMR relocation brackets, but i doubt that makes a hill of beans of difference.
?3) lastly, probably a stupid question, but do the washers go on the rod-end bolts? or the poly-bushing bolts?.
clunk-clunk.
2+ on embarrassing.
thanks.
doc
Old Oct 5, 2008 | 08:31 AM
  #33
Norm Peterson's Avatar
Norm Peterson
Some medium-strength grade ought to be enough. You don't want to have to heat the bolt/nut/joint to take it apart as is usually required with the 'red' stuff.
?3) lastly, probably a stupid question, but do the washers go on the rod-end bolts? or the poly-bushing bolts.
Whichever ones are running out of thread as the joint is tightened. Both if you're not sure.
Norm
Old Oct 7, 2008 | 05:54 PM
  #34
alloutt's Avatar
alloutt
I had the same problem so i put the stock ones back
sry to say but i like the stock ones better
Old Oct 7, 2008 | 11:38 PM
  #35
hurst cobra's Avatar
hurst cobra
i have griggs lca's and they clunk, and sometimes they squeak but the good news is they pulled 7 tenths of my 1/4 et and now i have a decent 60 foot time. i have gone back to my guys twice for tightening and re-greasing.....but the noises come back
Old Nov 13, 2008 | 08:03 PM
  #36
carolnjeff's Avatar
carolnjeff
Has anyone replaced the old bolts with new bolts? Did the clunking noise go away?
I pulled my LCAs and would like to put them back on but I can't stand the clunking sound.
Old Nov 14, 2008 | 07:23 AM
  #37
Norm Peterson
Next time they get pulled for regreasing, check to see if the poly pieces are longer than the inner sleeves that run through them.
Norm
Old Nov 14, 2008 | 07:38 AM
  #38
svtwin's Avatar
svtwin
Default Interesting tidbit
Polyurethane can be noisy if done WRONG.
WRONG #1 You cannot blend anything into Polyurethane.
Not even Graphite!
Nothing like this works because the family of Urethane
plastic does not like impurities.
(the word Polyurethane means blends of different Urethane plastics)
Graphite does not work for a couple reasons. If you put just a little in
the Urethane then the graphite is fully encapsulated by the Urethane
and the Graphite never touches the metal sway bar or a-arm shaft.
If you add a lot, then the Polyurethane falls apart because
it does not stick to the graphite (remember, graphite is a slippery lubricant).
You might as well throw handful of dirt into it.
Wrong #2 You cannot put in a grease zirk and tell people to grease it.
Polyurethane must have the right lubricant to make it quiet.
There are some lube greases that are bad for Polyurethane.
So there are all these greasable bushings caked up with the
wrong grease and the Polyurethane bushings are still Noisy.
Wrong #3 You cannot cost reduce your Polyurethane products and
expect a long and quiet life. Polyurethane is like anything else
important to you. It comes in many different grades. Polyurethane
can be designed and tempered a lot like steel.. If you design it to cure too
quickly it becomes harder. Harder Polyurethane is Noisier. Shorter molding
time means less cost. So between the correct chemistry and mold design,
it costs just a little more to do it right. But it sure pays off.
Old Nov 14, 2008 | 10:15 AM
  #39
VistaGT's Avatar
VistaGT
I did. After being on the phone with steeda for days they finally admitted it could be something beside an installer error lol. They said that they've had customer shop cars have the problems and if you replace the bolts that the clunking will go away.
I had to order the bolts from tennesee and when I put them in the noise was definitely reduced. At first I even thought the problem was fixed. No cigar though, I don't remember if it gradually came back or what but It's back now--though better than originally.
Old Nov 14, 2008 | 11:45 AM
  #40
Texotic's Avatar
Texotic
that sucks. I've got some BMR combo adjustable LCA's I haven't installed yet. How do I try to avoid the clunking noises? I've already got some of the correct grease.
