Big Brake kit
Old Aug 5, 2008 | 09:27 PM
EagleStroker's Avatar
EagleStroker
Default Big Brake kit
Ok, i've been researching quite a bit lately, but I would really like some user feedback. So whose running what, how do you like it, how much, and it has to clear a 19" rim. I'd perfer to run a 4 piston caliper, and i'm thinking slotted and drilled...
Old Aug 5, 2008 | 10:19 PM
houstonnw's Avatar
houstonnw
Default RE: Big Brake kit
You won't find a lot of support for a BBK in this forum.
https://mustangforums.com/m_5267714/tm.htm
https://mustangforums.com/m_5258855/tm.htm
And those threads are just on the second page. I didn't look any further back.
Are you using the car for HPDE's or do you just want something to look good behind the 19" wheels?
Old Aug 10, 2008 | 01:47 AM
foolio2k4's Avatar
foolio2k4
AP racing
Old Aug 10, 2008 | 09:22 AM
Simon1's Avatar
Simon1
For the most part, unless you are going to do dedicated track days, making multiple hot laps, you won't need any of the big brake kits. You can buy new OEM rotors or other name brand, pads of any of the aftermarket variety and change your rubber brake lines to braided stainless steel lines if you must.
Drilled slotted rotors are mostly for looks and offer no real benefits. In fact, most drilled rotors will crack prematurely. There are several guys on here that can tell you a simple pad switch with better tires will do more for your money than anything else.
I listened to some guys who really know their stuff and took their advice. I got some Hawk HPS pads and Powerslot rotors and the difference was dramatic. I needed the rotors because I hot spotted the other rotors and these were on sale. Otherwise, Iwould have kept the stock ones. I still have them actually. The brakes are quiet, low dusting and work well.
Set yourself a goal on what you want to accomplish and go fromthere.
Old Aug 10, 2008 | 12:19 PM
RodeoFlyer's Avatar
RodeoFlyer
ORIGINAL: foolio2k4
AP racing
AP Racing are actually second tier Brembo's
Great brakes are like great tires - they cover up a lesser talented driver's mistakes. Unless you are doing endurance racing, bigger brakes are strictly bling.
musnicki
Sep 23, 2015 07:11 AM
DoctorScary
Sep 9, 2015 07:53 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
