Handles Great But Rides Poorly
Yes Sam the Koni's made quite a positive difference. I was running a stock spring up front and Roush in the rear at the time. I have since put a Roush spring up front.
Roads are quite ruff this year. PA turnpike and RT 81 for a example. Suspected that the only escape from the sporty ride would be a spring with more travel. . I will live with what I got. I like look and handling more than a smooth ride
Hey Zip,
I have a very similar set up to yours (but Vogtland springs), and I found that adjusting the Konis can help a bit with ride quality. For my long drives I dial them way back from my track settings. I go with 1/4 to 1/2 turn to firm in front and full soft in back.
The full soft in back made a HUGE difference in ride quality from 1/2 firm (I tried that setting first and it was not fun on a long-ish trip). Since the Konis are only adjusting the rebound, you'll still feel the bump more, but she's much smoother overall.
Try it out. Hope that helps.
Best,
-j
BTW, the rest of the stuff is transmitting more noise into your cabin (not much to do about that but switch back to softer bushings), but this is just a tolerance thing. I don't mind it, and the radio can do wonders in this department.
Best,
-j
mungodrums
10-07-2015 04:01 AM
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
M3hunter
09-05-2015 03:42 PM
