Steel Braided Brake Line. Front or all four?
Just about to put some GT500 Brembos on the front of the car, and need to know if it will even make a difference to do the rear steel braided brake lines. I want them up front FOR SURE, but don't want to waste the extra money on the rears, since the fronts will do most of my stopping. Opinions?
Well, it's not going to be used for "street bling." I push a lot of power and need to stop it.
My opinion is you’d be penny wise and pound foolish to only do the fronts. A set of four ss lines is not that much more than the two. Even with the proportioning valve, I think you would be increasing the risk of rear line rupture by only doing the fronts (albeit small given you’re not using the car on a race track). Plus you’d be missing out on the firm pedal feel the ss lines give. I would (I did) do both.
When installing the lines, be sure you know the torque requirements of the bolts that connect the lines to the caliper. Most aftermarket bolts can’t take anywhere near the 50 foot pounds specified for the stock bolts.
That is kind of what I was getting at. Any guy that tracks his car isn't going to short himself on brakes.
kind of on topic, but kind of off... what brand SS Lines are everyone running? i see braided lines from Earls, Stop-Tech, Steeda, J&M, etc... any major differences or just get the cheapest you can find?
Steeda here. I got them thinking they would be the best fit, best engineered solution. However, I think the rears are too short. They are very taut when lifting the rear of the car.
