FRPP and Eibach
Old Nov 1, 2008 | 07:25 AM
gothamems's Avatar
gothamems
Default FRPP and Eibach
Another quick question....Are some of the components in the FRPP suspension package made by Eibach, i.e. springs...etc? Thanks
Old Nov 1, 2008 | 12:15 PM
RodeoFlyer's Avatar
RodeoFlyer
The springs and bars are Eibach
Old Nov 1, 2008 | 01:28 PM
gothamems's Avatar
gothamems
I thought so, thanks for the conformation.
Old Nov 2, 2008 | 08:49 AM
Poco's Avatar
Poco
I had an Eibach(FRPP handling pack) on my 06'GT.It handled very well but it turn the hiway into a washboard. A different set of dampners like Tokicos would work well those lowering springs.I did like the drop.
Attached Thumbnails FRPP and Eibach-hpim0196a.jpg   FRPP and Eibach-hpim0199.jpg
Old Nov 2, 2008 | 06:01 PM
sleepless's Avatar
sleepless
Yeah, I have the FRPP Handling Pack and am changing the dampers to Koni adjustables for the same reason; the FRPP dampers are to stiff for even mildly rough pavement.
Old Nov 2, 2008 | 08:11 PM
48prerunner's Avatar
48prerunner
So why are the Frpp springs cheaper than the Eibachs, i had heard they were the same also
Old Nov 3, 2008 | 01:29 AM
vSick's Avatar
vSick
I made the mistake of purchase both the eibach pro kit and the frpp springs before I knew that they are both the same springs. In my opinion, the frpp gives the car a slight rake whereas the pro kit is more even. Has anyone else noticed this?
Old Nov 10, 2008 | 06:52 PM
F1Fan's Avatar
F1Fan
No way, they are the same parts. All of the FRPP spring kits I've installed have the Eibach logo and part numbers still screened on them. You may have installed the rear springs slightly differently or not clocked the springs the same.
Also when you gun the lower damper bolts on with the axle in the air you are preloading the dampers isolators and this can cause the *** end to stick up as much as a 1/2"! You need to torque the lower damper bolts with the axle on the ground or loaded with a floor jack to get proper ride height at the rear of the car.
There are lots of ways to mess up even this simple suspension install and people are always finding new ways to do so. I've had the opportunity to correct several botched suspension installs with perfectly good parts for people who had them installed by people they paid to do the installation. Just because the shop has a sign and air guns doesn't mean they have a clue about performance suspension mods.
HTH!
Old Nov 10, 2008 | 08:06 PM
Texotic's Avatar
Texotic
yep, as others have said... identical parts.
baddog671
Jul 26, 2016 01:20 PM
PullTab
Oct 30, 2015 08:46 AM
warwickbass
Sep 20, 2015 04:51 PM
ccdguy
Sep 19, 2015 05:20 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
