Lowering 07 GT
Have you checked out the sticky thread https://mustangforums.com/forum/s197...ustang-gt.html
It should answer your questions and give you an understanding of what is required.
First, decide if you want to lower it for performance reasons or appearance reasons, and how important things like ride quality, noise, vibration, and harshness are to you. Consider the roads that you drive on. The reason for my suggesting that you do a little "leg work" up front is because what you're after will make some difference to people trying to make suggestions. It may even have some effect on just who replies here.
At its simplest, you need shorter springs. But 'simplest' isn't necessarily 'best' here, because other things besides ride height get involved. You'll almost certainly need an alignment even if you stop here.
A more satisfactory job would necessarily include new struts and shocks. For some, the adjustable versions are preferable (this is one of the things where a little better grasp of what your ultimate goal is would have helped). You may (or may not) need to swap additional pieces (stock panhard bar for an adjustable one, LCA relocating brackets, etc.). Perhaps a few other things if either hard cornering or hard straight-line performance driving is going to be big part of the car's life. Need you to tell us that kind of stuff, otherwise you'll mostly get peoples' own preferences and have to sort them out anyway.
The bolts that your friend mentioned may be "one-time use" fasteners, which according to Ford factory service procedures get tossed and replaced if you undo them. There are several of these things in the S197 suspension. That said, some people have been able to get a second use out of some of those one time use parts.
Poke around the various vendors that have links down the right side of the page or are listed at the top of the main forum index. In addition, there are a few others who are specifically involved in suspension modification, such as Sam Strano at www.stranoparts.com or Steeda ( www.steeda.com ).
Norm
Norm
I have a set on another car and I guess they're OK. But they lowered that car more than advertised and ended up making it way too low even for easy street driving.
Norm
Regarding the Corvette guy who mentioned "Stock" bolts, here is what he is talking about: The Corvette does not have springs (not like our cars), it has a transverse leaf spring front and rear. Its basically a flat (maybe 3/4 in thick) composite bar maybe 4 ft long mounted transversly (ends of bar point towards sides of car). On the ends of the bar, on each side, is a bolt. The bolt is threaded and can be turned to raise or lower the car. Yes, from the factory, the Corvette is height adjustable or if you like (and even better) can be cross-weighted.
