DIY spring/shock install Q
Thanks Norm but when you have cheap metal, you have cheap metal.
The threads are stretched after several uses...
Still no excuses, I should buy a good one but I don't do enough of these.
Especially since I don't do a lot of collision anymore.
So, let me get this straight. I have the Pro-Sport springs on stock struts right now. I have a set of D-Specs waiting to go in. When I install these, I won't have to have to rent a spring compressor? I like the idea using coat hangars. Even if the springs expand a little, the hangars should hold them tight enough to assemble by hand.
Cheers!
Cheers!
To the OP:
http://www.sears.com/shc/s/p_10153_12605_00947057000P
They worked just fine for me, you don't have to worry about renting a fubar set from autozone, etc. etc. Just put a bit o grease on the threads before and clear them off after.
I love doing things myself but I pretty much insist on having the right tools for the job. Makes things a lot less stressful.
Cheers!
Cheers!
For my 08 I was not able to do this as there were a couple of rubber/plastic parts required from the old assembly.
good info guys thanks. i really dont want to buy/rent a compressor but i also dont want to lose an eye. zsporta's idea of just buying new upper strut mounts sounds good but i need some of the plastic/rubber parts from the old assembly? Can anyone else back this up?
I had to use a spring compressor to get the stock springs off the stock struts. But when putting the Steed springs on the new struts, they were short enough to push down a little by hand and get the nut started. So didn't need a spring compressor to put the shorter springs back on. That saved some time.
Per the instructions;
"3. With the strut and spring disassembled, remove the factory upper strut
mount. Then remove the rubber spring seat from the factory upper strut
mount Pic 1& 2
4. Remove the spring seat base from the new assembly. Insert the new spring
base into the factory rubber spring seat. Be sure to keep the billet spring
seat base face up to prevent disturbing the bearing inside. Pic 3"
In addition on my 08 there was a plastic wrap around the lower part of the factory coil and I was advised to install this on the new springs.
