tire/wheel size - 9" wheel, largest tire?
Old Dec 31, 2008 | 12:52 AM
sharkbait20's Avatar
sharkbait20
Default tire/wheel size - 9" wheel, largest tire?
real simple.... what is the widest reasonable tire to put on a 9" wheel? 275 too wide or skinny?
car is not a DD, but is driven fairly hard when its taken out, never taken to the strip though (yet). am looking for the staggered look.
help greatly apreciated! thanks
Old Dec 31, 2008 | 01:02 AM
bronxbomba63's Avatar
bronxbomba63
I believe 275 is the widest you can go.
Old Dec 31, 2008 | 01:17 AM
sharkbait20
is that going to fold the sidewalls do u know?
Old Dec 31, 2008 | 06:57 AM
Sleeper_08's Avatar
Sleeper_08
You should g to www.tirerack.com, shop by Brand, pick the tires you are thinking of and then click on "SPECS". It will then show you for each size what the recommended rim widths are for each size.
Old Dec 31, 2008 | 07:54 AM
Norm Peterson's Avatar
Norm Peterson
Under cornering loads, all tires will distort and deflect laterally (sideways). 275/40's on 9" wide rims will deflect more than 275/40's on 10" wide wheels, and you might even be able to make out a slightly "softer" feel to the response on the 9" rims vs 10" in back to back driving with the two different sets.
Dragstrip activity is somewhat less sensitive to wheel width vs tire size, since there is not much lateral load happening (hopefully, anyway). But the combination of low inflation pressures and wide tires/narrow wheels can adversely affect directional stability at the big end.
Norm
Old Dec 31, 2008 | 08:50 AM
OEWheelsShawn's Avatar
OEWheelsShawn
Disabled at Vendors request
It's recomended to go no larger then a 275. The 275 look great on a 9" wheel and give you the maximum amount of traction.
Old Dec 31, 2008 | 10:59 AM
sharkbait20
shawn, I looked through your website and saw some pretty amazing things as far as wheel packages for cheeeeeeppppp. where are you guys located out of?
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Mr. D
Wheels & Tires
Aug 8, 2015 05:43 AM
