ford racing strut bar
Thats what they said about my steeda one but I contacted steeda directly and they told me it would be fine with the plenum cover, they did say that in rare cases you had to remove the spacers from the rear screws of the plenum cover but 9 out of 10 times it went on just fine, mine was one of the nice.....
not necessarily. I bought a Granatelli STB and it wouldn't fit over the plenium cover, despite Granelli's claims that it would. I think there may be some varience in engine height w/ how they are sitting on the mounts, which could be why the OP is having some problems.
Worst case scenario, if lowering below the mounting position doesn't work, you can use some washers over the screws to shim the STB up
If you don't have the engine cover it should drop right over the strut bolts. Maybe the STB you have got bent somehow. I have the one for the GT(parallel beam part#M-20201-S197) and it took like 3 minutes to install. Where is the problem with yours? Are the holes not lining up or is there contact with the engine somewhere?
So the only thing I can think is that the brace is damaged... there really shouldn't be anything complex with its fitting.....
