question on Tire wear
Ok. I've got about 25K miles on my stock tires. And surprisingly, they're doing pretty well. Only a little life left but because they've stopped giving me hours at work, I can't afford a new set just yet. I only drive about 2mi a day anyway so they'll last a few months the way I drive.
Here's the question. I have a lowered car. The rear tires are more worn than the front. Rear's have an even wear whereas the front has less tread on the inside because of the change in camber from the lowering. I read somewhere that it was smarter to leave the tread up front for grip when it rains(ie: taking a turn, even at a low speed, we don't understeer into a wall or something) but should I move rotate them anyway because we have 300hp that needs grip?
Thanks for any input in advance.
My personal preference is to always keep the best pair of tires on the front. If I get in too hard or fast then they may save me.
The control of the HP is by my right foot so it is up to me how much is being used at any time.
the tires with most tread should always go on the rear.
when i was in high school i got a new pair of tires put on my rear-drive car. the tire shop correctly put them on the rear. it was winter and i told them i was more concerned about stopping then starting and had the new tires moved to the front. i'm sure the tech was like, "whatever pimply-faced know it all". so i'm driving down the road in the snow and what happens? my rear-end gets loose and i do a 180 down the road.
i remember a representative from michelin writing into motor trend about some bad advice they gave, which was to put newer tires on the front. the letter from michelin said to put newer tires on the rear.
also, from an article of police fleet manager sept 2007. both goodyear and bridgestone-firestone said to put new tires on the rear:
"Second, when you put just two new tires on a car, put them on the rear. Under slippery conditions, better tires on the rear prevent oversteer, even in FWD cars."
http://www.hendonpub.com/publication...efleetmanager/
timothyrw
I stand corrected. Thank you.
After further research I also found this article that says to always put the new ones on the back and talks about their experience trying both http://www.tirerack.com/tires/tirete....jsp?techid=52
I guess my new pair of KFW2s go on the back.
I would much rather have tread in the front if it rains. Losing the front end does not leave many options for recovery other than eating a curb etc. My car ate the inner tread on my Nitto's to the point the chord was showing. I couldnt tell since the rest of the tire was perfect. I now have MM camber plates to fix the issue and new tires.
