Lower control arms?
Old Mar 4, 2009 | 10:51 AM
Smooth_J's Avatar
Smooth_J
Originally Posted by moosestang
If you are lower, get relocation brackets.
Not to cut in, but I have a question. Lower by how much? I am lowered by 1" all around - Roush Stage 2 Kit.
Old Mar 4, 2009 | 11:35 AM
05gtgreen's Avatar
05gtgreen
Could someone please answer my question about installation. Thanks.
Old Mar 4, 2009 | 11:54 AM
Smooth_J's Avatar
Smooth_J
Its the BMR, but its pretty much the same process.
https://mustangforums.com/forum/2005...on-w-pics.html
Old Mar 4, 2009 | 02:16 PM
05gtgreen's Avatar
05gtgreen
Thanks for the reply!
Old Mar 4, 2009 | 04:36 PM
Sleeper_08's Avatar
Sleeper_08
If you are looking for additional info here are a couple of Taco Bill links;
http://forums.bradbarnett.net/showthread.php?t=460206
http://forums.bradbarnett.net/showthread.php?t=461715
and for good measure here are the Steeda instructions
http://www.steeda.com/directions/555...ntrol_s197.pdf
Old Mar 4, 2009 | 05:50 PM
moosestang's Avatar
moosestang
Are these things pretty easy to install? Do I have to grease them first or are they good to go? I purchased the j&m ones. Is installation just as simple as removing the old ones and putting the new ones in? Can I let the rear end hang loose or do I have to hold it up with jack stands. Thanks.
Very easy and you can reuse your stock bolts/nuts. The front bushings have to be greased and installed, but the extreme joint is pre-assembled and greased. It's very easy to install the front bushings and sleeves. Make sure the grease fitting is pointing down and that the offset is pointing inward, in other words, the bar should be offset towards the outside of the car. You can let the axle hang, but I keep a jack under it just to make it easier to line up the holes for the control arms. Do one side at a time and you'll probably have to pull or push the axle to line up the holes, but it's not that hard. Taking the tires off makes it a little easier to remove and install the arms, but be sure to torque the bolts when the weight of the car on the axle.
Old Mar 4, 2009 | 09:39 PM
5SPD07GT's Avatar
5SPD07GT
Official Site Sponsor
i have the same question
Old Mar 5, 2009 | 01:07 PM
moosestang's Avatar
moosestang
I am lowered 1.5 inches all around and noticed an obvious difference in ride quality after adding the CHE lca relocation brackets. It just rode much smoother with the lower control arms parallel to the frame. You might want to install the BMR brackets because you have more mounting options for different drops. At the very least traction will improve.
Old Mar 8, 2009 | 04:52 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
like moose said you want the LCA's parallel to the ground... many feel that 1 inch or less drop doesn't require relocation brackets but you need to check your pinion angle first ....JMO
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
