Suspension parts just arrived!!
So I just received my suspension parts today from StangSuspenion!
This Saturday I will be Installing Tokico D-specs, Eibach Pro Kits, And a BMR adjustable Panhard Bar. Just have to rent a spring compressor than I should be good to go! Thanks to TacoBill's stickys im pretty confident on how im going to go about this install.
Yeah no kidding his instructions are awsome w/ pics! Ill take before and after pics when im done. Than off for an alignment sunday! Want to just jump on it now but busy until saturday... Got to spend time with the GF till than.
yeah for sure got locktite-blue and torque wrench from my buddy from wyotech he got he let me borrow it for this install and he will be there to assist me.. And I got all the torque specs from Tacobill's sticky. Just have to rent a Spring Compressor from autozone or kragen..
Location: from Warwick, RI but live in Ft Walton beach, FL
the install on all those items is so easy have fun. the only hold up i had was getting the stock panhard out, the passenger side was really wedged into the bracket. and be careful when removing the springs from the compressor it can still be very dangerous, i sent one flying past my head into the front yard.
P.S. Make sure you do the spings and d-specs first, then lower the car measure the ride hight using chalk or grease pen on the rear shock, jack it up, install and torque the panhard at the NEW ride hight by jacking the rear axle up until the marks you made are lined up on the rear shock
Yup will do I seen A guy loose some teeth as well as 20 stitches to his lip from a spring compressor malfunction..Ouch after I seen that im going to take my time definitely.. Ill have all day no rush.
i just updated my post after you posted just make sure you do the install in that order so you dont mess the alighnment that bad, and less jacking/lowering of the car
will do thanks Redsox401 for the advice. I follow the steps on your post as stated. ''Make sure you do the spings and d-specs first, then lower the car measure the ride hight using chalk or grease pen on the rear shock, jack it up, install and torque the panhard at the NEW ride hight by jacking the rear axle up until the marks you made are lined up on the rear shock '' Thanks again!
