Wheels and Tires
Old Apr 2, 2009 | 11:02 AM
sailing220's Avatar
sailing220
Default Wheels and Tires
Hello everyone - been gone fore awhile but I'm back.
What is the biggest wheel width/tire size combo I can put on the rear with an 18" wheel?
Old Apr 2, 2009 | 12:21 PM
MustangGT0405's Avatar
MustangGT0405
Biggest I would go is 18x10 with a 305/45/18.
But some have shoehorned in a 335, but then you have to start relocatiing suspension peices.
Old Apr 2, 2009 | 05:24 PM
sailing220's Avatar
sailing220
Do I need wheel spacers with 305s?
Also, what about a 315? I have 17" rims right now.
Old Apr 2, 2009 | 06:20 PM
UrS4's Avatar
UrS4
You would need a custom 17x10 to run a 315 and have it not rub on suspension stuff. Probably a 36-38mm offset.
I have heard of 305 fitting on 20's.
315 on an 18 or larger rim would need a 11 inch wide rim.
Old Apr 5, 2009 | 11:02 PM
Poco's Avatar
Poco
I've run 295/45/18's on 18x10's. It pretty tall at about 28.3" overall diameter.If you like a rake that is.My 07'Gt is lowered and with that set up you lose the level set up.Your speedo might go off a bit. I ran 255/45/28's on 18x9's up front. The ride was pretty good. 305/45/18's are 28.7" tall. Maybe just a bit tall and create more understeer.
robcy
Suspension
Oct 27, 2015 11:14 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Oct 7, 2015 07:02 PM
mungodrums
Sep 28, 2015 05:45 AM
Sep 8, 2015 11:50 AM
