Rear Lower Control Arms- why?
Old Apr 21, 2009 | 10:42 PM
Steves07GTCS's Avatar
Steves07GTCS
Default Rear Lower Control Arms- why?
I'm in the infant stages of learning about suspension setup- Lower Control Arms (specifically rear LCA's): what do they do, and what is the end-result reason for upgrading them? Thanks, please don't kill me for asking basic questions.
Steve
Old Apr 22, 2009 | 09:09 AM
Norm Peterson's Avatar
Norm Peterson
They perform two basic functions. Locating the axle ends so the axle stays under control, and isolating the chassis against whatever roadway roughness the tires encounter.
Their design, which is generally considered to include the bushings or other pivoting mechanisms at the axle and chassis ends, is a compromise between the accuracy of axle end location and the reduction of noise/vibration/harshness (NVH) transmission.
Problems arise when the OE compromise of softish bushings (NVH relatively important) gets in the way of axle location under heavy acceleration load, or in some cases where the soft bushings allow the axle to steer a little too much while cornering. When bushings are deformed, energy is stored in them, but this energy can be spit back out under certain conditions. Most folks know the resulting effect as wheel hop.
If you don't mind a bit more NVH, stiffer bushings help. But here's where you need to make a few of your own choices and compromises. Simply stiffening everything up with the usual polyurethane bushings will help the wheel hop issue, but the same poly stiffness also acts in other directions within the bushings and interferes with the car's handling balance. When the car rolls (and the axle doesn't, at least not as much), you actually want some bushing softness so that this roll does not generate large forces that ultimately reduce rear tire grip. Right about here is where one of the dragstrip vs cornering decisions may show up.
Generally, this is an oversteer-ish effect, and although you may not even notice this in most reasonably normal driving it will be there if for any reason you ever do find yourself up near the limits of lateral tire grip. For some, that's a fairly frequent intentional occurrence; for others, perhaps it never happens - at least not intentionally.
Fortunately, there are choices available that reduce this "bad-direction stiffness" handling interference while preserving the stiffness in the "good" directions. Not "something for nothing", though - the solutions are more complex/costly/perhaps less durable (poly/rod or rod/rod LCAs, Johnny Joint arrangements, etc.). It is also possible to "tune around" the handling issue, although that involves swapping the rear springs and/or the rear sta-bar for slightly softer pieces.
Norm
Old Apr 22, 2009 | 09:44 AM
rford426's Avatar
rford426
^^^there ya go...good job norm
Old Apr 22, 2009 | 01:17 PM
BMRFabricationSales's Avatar
BMRFabricationSales
Former Sponsor
Norm covered it perfectly. If you do chose to replace you control arms please consider BMR. We have several different options and our products can withstand race conditions or everyday street use. Here is a link to our site. If you have any questions please give me a call.
http://www.bmrfabrication.com/
Old Apr 22, 2009 | 02:57 PM
Sleeper_08's Avatar
Sleeper_08
To complement Norm's excellent explanation here is a link that provides a more graphical though less complete description - http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
In my case last year I put in poly/poly LCAs but this year I switched them to poly/rod LCAs. However I am one of those who is willing to trade off NVH for performance and do run the car hard on lapping days.
If you want to really get into the subject check out the Reading List thread.
Old Apr 22, 2009 | 07:18 PM
Steves07GTCS
Wow. Thanks for the information, that was much more in depth than I was expecting. Very informative.
Steve
Old Apr 23, 2009 | 04:55 AM
MTAS's Avatar
MTAS
I have BMR LCA (tubular w/urethane bushings), relo brackets (welded), adj. panhard rod and rear sway bar w/billet endlinks. The improvement over stock is huge. The rear isn't harsh by any means, just noticeably firmer and stays planted. I can't say enough about the stuff and will be installing their front sway bar soon.
Old Apr 23, 2009 | 10:46 AM
BMRFabricationSales
Former Sponsor
Dave, love the car, thats ones sweet ride!! Thanks for the kind words.
Old Apr 23, 2009 | 11:03 AM
MTAS's Avatar
MTAS
Thumbs up
Thanks Dennis, I figured you're recognize it And for folks who aren't aware, BMR is a class operation - great bunch of guys who know their stuff. Oh and Dennis, a buddy of mine from West Palm Beach is coming up here in June and we'll be installing your rear sway bar w/billet endlinks and adj. panhard rod on his car, as well as your front sway bar on my car
Old Apr 23, 2009 | 02:11 PM
BMRFabricationSales
Former Sponsor
Dave, give me a call when your friend arrives, i'll make sure the bar is ready for you. Your welcome to bring him by, we can give him a tour of the shop.
