Lowering, camber adjustment
I lowered my 2006 GT in Jan 2008. Now the front tires are worn to the cords on the inside of the tire - the outside tread is normal. I suspect the lowering reduced in too much negative camber. I have 255/45 18s on aftermarket 18X9 rims.
In addition to 2 new front tires, what is recommended to "fix" this? Do I need camber plates/bolts? Can the front end be aligned adequately with the stock set-up?
I apologize if this has already been answered in previous posts - I did look, but didn't seem to find a post to exactly match my predicament.
If it is the camber then I'd ask, how much do you want to spend? The cheapest solution is to get a set of eccentric camber bolts. They go in the bottom of the strut where it mounts to the spindle. If you are interested in a better solution, I have a set of used J&M camber plates sitting in my basement. They replace the stock upper strut mounts and give not only a much more solid mount (i.e. eliminates common "thunk" noises) but also very easy adjustability. They are in great shape. PM me if interested.
If you didn't lower it too much, then camber bolts can fix the camber issue.
And yes you can roughly check the camber yourself, but it sounds like you are way under (too much negative camber), and you need something to correct it. Plates are the best solution, but camber bolts ($20 a set) are reasonable and work well, too, if they can provide the amount of adjustment you need. I used Eibach bolts to adjust mine, but it was only off by 0.75* on each side after lowing the front 1".
And toe should be checked/adjusted as mentioned as well.
Argonaut, tx zstang - thank for your help and comments. After I get the new tires installed I will have the alignment checked. My only concern is whether a generic alignment shop will be able to install camber bolts or camber plates - I guess I'll ask them and see what they say.
Argonaut, do the shocks need to be removed to install the camber plates? (Please , no laughing....) If so, this might provide an excuse to upgrade from OEM shocks to adjustables.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
CutterWolf,
I used the Eibach Pro-Kit (Ford Racing) coils that lower by a little over one inch. Is there enough inherent adjustability in the suspension to adjust the camber as-is, without adding camber bolts or camber plates? I don't know, nor does the local Ford dealer or a local alignment shop. If so, this obviously might be a simpler and certainly a less expensive solution.
Thanks again to all posters - I have found your comments to be quite informative and helpful.
ffk pennywise,
Just looked at Brennspeed web site - in their description of their (BMR) camber bolts that the factory setting has no camber adjustment. Did you have to remove the shocks to place camber bolts?
