Adjustable FRONT & Rear swaybars
I am looking for adjustable front & rear anti sway bars for track use.. which brands do you guys prefer & where is the best pl
ace to buy them ? THANKS! Are the Eibachs both adjustable??
adjustable sway bars ? Huh ? Are you asking about adjustable shocks ?
there are a few companies that make adjustable sway bars, but you can only adjust them by shortening or lengthening them where they attach. I think a good sway bars that fits your car and some good springs and shocks would be of much more benefit than adj sway bars.
My front Steeda sway bar has three holes in the end of it to make it adjustable. So far I've run it only in the center hole.
Adjusting it with the stock links is a pain but now I have Sam's rod end links and may try swapping holes later this season.
I have the same as Sleeper's the Steeda comp sway, I personally have mine set to the hardest setting and I am pleased with the results. It doesn't take long at all to swap the tension, just one ratchet wrench and there ya go...
My Steeda rear bar is not adjustable. The PNs are Front Anti Sway Bar Steeda 1 3/8 bar 555-1050 and Rear Anti Sway Bar Steeda 7/8 22 mm bar 555-1056.
My plan was to do the final tuning by only adjusting one end of the car,i.e. the front. Up to now my learning curve has been so steep that tuning the bar has not yet been tried.
I am also running Steeda Competition springs 555-8241.
they do not offer a rear that is adjustable, just a larger Diameter...
http://www.steeda.com/products/comp_...h_endlinks.php
The rear steeda Comp is $$$$, but you do get endlinks with it.
I think the only two fully adjustable sway bar kits (front and rear) are hotchkis and stillen. i am not sure of any site sponsors which carry them. American muscle carries the eibach sway bar kit which has a standard front and adjustable rear for $330 which is an awesome price.
EDIT: here is the hotchkis kit. http://www.stranoparts.com/partdetai...D=80&ModelID=5
