Cutting springs?
Old Jan 20, 2010 | 10:03 AM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
Default Cutting springs?
I've heard of it, and I understand the concept, but is it a good idea? I don't really care if it sacrifices handling a tad bit, I just want to lower the car.
Old Jan 20, 2010 | 10:22 AM
gmoran1469's Avatar
gmoran1469
Seeing as you are asking this question in the first place, no it is not a good idea. You need to know what you are doing. If I were you I would just buy a lowering kit.
Old Jan 20, 2010 | 10:42 AM
jodadejss06gt's Avatar
jodadejss06gt
springs aren't more than 250. Just buy some! You'll end up wasting your time cutting them becasue eventually you'll get springs that are meant to do the same thing.
Old Jan 20, 2010 | 10:51 AM
bingo2's Avatar
bingo2
There have been other threads regarding cutting springs; do a search....the consensus is overwhelmingly negative.
Old Jan 20, 2010 | 11:44 AM
kingsofcrunk's Avatar
kingsofcrunk
Cutting springs can be dangerous. Plus you cannot guarantee equal cuts on both sides. I highly recommend avoiding this at all costs. Save your money and get springs, they are not that expensive.
Old Jan 20, 2010 | 12:53 PM
05 Mustang's Avatar
05 Mustang
please do not cut your springs to lower the ride height of your car.....spend the money and do it right...
Old Jan 20, 2010 | 02:06 PM
NuclearMuscle523
That's what I thought, just didn't know the general opinion. And I do know what I am doing.
Old Jan 20, 2010 | 02:36 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
You can get cheap springs (not that I'd recommend that), but even really good springs like Steeda Sports or Ultralites run $250-ish shipped to your door. Ultralites are $249.99, Sports $259.99.
Cutting ruins the tempering. You don't know exactly what kind of drop you'll get, and also the spring rate changes too, but often not enough to counter the change in height. This isn't something as 'simple' as maybe building a STB or even something like a PHB. Springs are active, dynamic components that actually hold the entire car up.
Old Jan 20, 2010 | 08:28 PM
Norm Peterson's Avatar
Norm Peterson
Nuc - I peeked at your profile.
When you cut down a spring that's OE for the car in question, the strain energy (1/2 Kx^2) per unit volume goes up, which can be expected to result in the spring settling over time more than it would if it was left alone. That's separate from getting the amounts to be cut right (and equal), that the spring coil ends still agree with any required spring clocking, and that the cut is accomplished without either annealing any part of an active coil or adding more carbon to the metal and making it brittle.
I've cut springs before. A couple of times successfully, and once that decidedly was not (the top coil broke free on a spring that was not held captive by either a shock or a strut). An iffy proposition that I can't generally recommend.
Norm
Old Jan 20, 2010 | 09:19 PM
NuclearMuscle523
So you are basically saying that I alter that potential energy of the springs, making it stiffer in terms of angular strain, IIUC? I am normally familiar with strain energy being altered by some sort of elastic deformation.
