Lowering, do I need offsets?
Old Feb 10, 2010 | 03:04 PM
gmoran1469's Avatar
gmoran1469
Default Lowering, do I need offsets?
I am using Steeda Sport springs, and Koni STR.T dampers. I am running a Steeda Ultra-lite 18x9.5 and plan to run 275/40ZR18's on all 4. Do I need offsets to not rub?
Old Feb 10, 2010 | 03:30 PM
Sleeper_08's Avatar
Sleeper_08
I'm running the Steeda Ultra Lite wheels (PN 013-0000) and they have a 45 mm offset.
In the summer I run 285/40/18 tires and before the car was lowered there was no rubbing. After lowering with Steeda Competition springs and with the extra weight of the SC etc on the front it it only rubs slightly on the inner left front when parking - i.e. full lock.
Old Feb 10, 2010 | 10:38 PM
zero2sixd's Avatar
zero2sixd
I have the same springs and wheels with 275/40R18 and there is no rubbing at all, even at full steering lock.
Old Feb 11, 2010 | 01:15 AM
peetiewonder's Avatar
peetiewonder
just fyi, offset is a rim measurement (distance from the center to the mounting surface), and not so much a physical thing. spacers are physical devices that can be used to decrease the effective offset of a wheel. on a 9.5-10" rim (which i'm assuming you'll be running with 275s) ~45 offset is the standard offset to run for our cars.
This link should give you an idea about wheel sizing to help you out.
http://www.discountedwheelwarehouse....ment_Guide.cfm
Old Feb 11, 2010 | 07:47 AM
gmoran1469's Avatar
gmoran1469
Doh, that's what I had meant, spacers.
Old Feb 11, 2010 | 02:12 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
You'll be just fine with those wheels and tires
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
NYstang
Sep 30, 2015 09:56 PM
