Steeda HD mount install questions
I am eventually going to be installing HD strut mounts and the directions are sorta crappy. The question I have, is... It tells you to line up the steeda logo in the plate with the outside of the car.... So would that logo be closest to fender, or logo go towards front of car? Anyone have any tips as to how to position it? Thanks
I've had mine apart 4-5 times swapping springs back and forth. I pull the mounts apart, wipe out all the grit and dirt that accumulates internally and use the supplied grease to relube the needle bearings. You'd be surprised at how much crud gets inside after just 6 months of usage...
I used the lube to grease up the O rings that are on the bushing that the strut shaft goes thru. The bushing with the O rings squeezes into the lower plate and you will tear up the rings if they are not lubed. I had mine on the car for a couple of years before I changed springs. I had to change all the O rings because they were all torn. Assemble the upper and lower plates, put a nut on one or two of the studs to keep it together, assemble the strut with the springs and strut pad. Then you can take the nuts off and install the strut in the car.
