camber bolts?
Old Feb 20, 2010 | 09:16 PM
08blackoutstang's Avatar
08blackoutstang
Default camber bolts?
so i am installing my lowering kit tomorrow and i need to know where the camber bolts go and how to install them and how to adjust them....? thanks A LOT o and when i get my alignment done after will they adjust them or do i have to.....? thank you
Old Feb 21, 2010 | 09:03 AM
StickShifty's Avatar
StickShifty
you install them in the top hole on the bottom of the front strut assembly. you basically put the bolt in, and turn the bolt so it kicks the top of the spindle/brake rotor out towards you. then you tighten the nut on. i have mine set all the way out, to give me the max. they are very simple to install.
basically its a bolt with a cam on it, it replaces the stock strut bolt/s. you can use 2 to get more of an angle.
Old Feb 21, 2010 | 09:19 AM
08blackoutstang
perfect thank you
Old Feb 21, 2010 | 02:34 PM
6-Speed's Avatar
6-Speed
Did you get the Ingalls type, which are sold under a variety of names or the type where you have to slot the strut mounting holes? If you have the Ingalls type you can download instructions at their site.
http://www.ingallseng.com/instructio...downloads.html
Old Feb 23, 2010 | 09:49 PM
So_Cali's Avatar
So_Cali
Is there any difference in camber bolts? I know Progress makes a set as does Ingalls. Is any one better than the other in terms of quality?
Old Feb 23, 2010 | 10:32 PM
08blackoutstang
i went bmr
Old Feb 24, 2010 | 10:58 AM
StickShifty
i have BMR ones, the quality is nice. Steeda also makes a shim kit. i have no idea how that installs.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
2poor4u2
Sep 26, 2015 11:08 AM
