Front strut and lowering spring install
Old Mar 18, 2010 | 03:54 PM
hiltsy845's Avatar
hiltsy845
Default Front strut and lowering spring install
I plan on installing my Steeda Ultralight and Koni setup tomorrow. I have some cheap spring compressors, but they seem like they could slip off at any second and go shooting across the garage at 200mph.
Has anyone tried placing a jack under the a-arm and decompressing the assembly while still on the car? Will the a-arm drop low enough to relieve spring pressure? What about the a-arm angle when dropped that low. I have 2 floor jacks and jack stands. Anyone have some input on this?
Old Mar 18, 2010 | 10:01 PM
Lv XLR8N's Avatar
Lv XLR8N
I havent heard of anyone doing it that way. What spring compressors do you have? I know craftsman's work.
Old Mar 19, 2010 | 11:32 AM
hiltsy845's Avatar
hiltsy845
I think I got the compressors at Advanced Auto Parts 10 years ago. Basically just hooks over the coils with a piece of allthread inbetween. The shape of the hook is all that holds it on the coil. I have seen some newer ones that have a pin that is inserted after the compressor is slipped over the coil to keep it from flying off.
Old Mar 19, 2010 | 11:36 AM
m260gt's Avatar
m260gt
dont know about the new body style, but i did my springs that way. un hook everything. put a jack under the A arm and lower it slowly. have to have the car raised up on jackstands for it to go low enough, but it will. just have to use a pry bar to get the springs loose, but they wont go shooting across the room. spring compressor would have been easier probably though
Old Mar 19, 2010 | 03:43 PM
hiltsy845's Avatar
hiltsy845
Well I guess I will give the spring compressors another shot. The rate on these factory springs is pretty light. Shouldnt be a big deal.
drfister
May 3, 2018 10:38 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
GentleBen
Aug 28, 2015 12:58 PM
01moostanggt
Aug 17, 2015 01:22 PM
WDScott
Aug 17, 2015 06:38 AM
