Watts linkage question
Old Mar 26, 2010 | 11:05 AM
marcuskeeler's Avatar
marcuskeeler
Originally Posted by Sleeper_08
The noises are rattles and clunks on rough road surfaces - like the parking lot at work.
On the track last year everything was quiet but as you know both Mosport and TMP are pretty smooth.
I see you have an upper adjustable mount too. Got to be something loose or worn on that or the watts.... Unless it's simply your exhaust knocking on something ?
Old Mar 26, 2010 | 01:27 PM
Sleeper_08's Avatar
Sleeper_08
That's why I am planning to check everything before hitting the track again.
Old Mar 27, 2010 | 10:21 AM
marcuskeeler
I did have some amount of crashing on the rear end initially. When I looked I found that the drivers side axle clamp was hitting the exhaust which kinda bummed me out for 5 minutes until I realized the muffler hanger wasn't engaged in the rubber properly so the muffler and over-axle pipe were sitting too low.
Easy fix
Old Mar 27, 2010 | 11:31 AM
Sleeper_08's Avatar
Sleeper_08
Easy fix
Thanks - I'll check that when I get a chance to crawl underneath.
Old May 3, 2010 | 05:38 PM
marcuskeeler
Did you check out the noisy rear end yet Colin?
I installed a Fays linkage setup onto Bills car last week for him and he took it to Mosport at this past weekend. He was raving about it for hours afterward, I think it 'hit the spot' with him !!
Old May 3, 2010 | 07:36 PM
Sleeper_08's Avatar
Sleeper_08
I'm still working on it. I'll send you a PM.
Old May 6, 2010 | 05:44 PM
StickShifty's Avatar
StickShifty
for the first question. i think it will just bind up, both side of the watts move the same. if one was longer they would bind up.
as for the noise, it might be the metal bushings. i am having a problem with mine, the one is making a slight thud at low speeds.
Old May 6, 2010 | 05:48 PM
Sleeper_08's Avatar
Sleeper_08
I'm sending you a PM
Dokilar
15
Oct 16, 2015 08:13 PM
flash_xx
Oct 16, 2015 07:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
