Uneven tire wear
the only time it makes sense to me to rotate tires is to delay a new tire purchase. I'm going to do that just to hold me over another month until I buy my new staggered wheel and tire setup. currently my tires are all wearing dead even from side to side, I've just killed the rears from burnouts and doughnuts staggering will never fix a problem related to tire pressure and wrong alignment settings. it makes sense when you think about it, the front would have to have the opposite problem/settings as the rear for one to even out the wear of the other. it makes more sense to just keep an eye on the tire wear and adjust the pressure as needed.
Mind if I ask a couple of related questions?
I'm assuming that recommended pressures are set with the full vehicle loading in mind, unless a separate set is given for some light load condition. Does that suggest that the recommended rear tire inflation pressure in particular actually represents slight overinflation with respect to light load conditions? But provided by the mfr anyway due to full knowledge of the poor average level of owner attention to tire inflation pressures, and due to it being better to be a little high for the light loads than too low for the full loads?
Norm
Norm
Am I correctly interpreting what you mean by "drives a tad on the aggressive side" to be more indicatative of hard acceleration and braking rather than hard cornering?
You certainly see a wider variety of vehicles and their overall undercar condition (and their drivers) up close than I ever will. I'm looking to see how well a couple of things that I suspect line up with what you actually see happening.
Norm
Norm
I may get 20k out of a set of tires and brakes.
Were as if it was my dad driving the same car, he would get 40k out of both.
Driving styles have a lot to do with it as you know.
No Offence Stoenr but even with a wider tire, riding at 18 psi is not good for any tire. you are putting way to much stress on the sidewall causing chafing on the inner wall. plus the second you hit a large pothole, or un seen bump your gunna be buying a wheel. I have 315's in the rear and they are wearing even at 35 pounds. I agree to just let a few pounds out and see if that helps. If not the i guess your outa luck. Maybe you just need to stop doing so many burnouts! :P
Ok, maybe in another thread I may have said that regarding drag radials at the strip, lol
door sticker psi is great for when you have the OEM tires and/or you have the same size tires, but different brands
the second you change out your tires though to a different size, that sticker is worthless. You have to figure out the optimum pressure, and keep a minimum spec in mind.
anybody remember the Firestone debacle back in 2000-2001? That was a combination of 3 things.
I highly suggest that you only run 30 psi in the tires at the lowest...period. Too low a pressure and you run the risk of sidewall damage. Be very careful here. Running 10-20 psi at the track is one thing. The tire never really gets hot. Running under 30 psi on the highway is 100% different. The tire will get to an equilibrium temperature...and the less air the more sidewall will be crushed. This will break down the rubber/steel/nylon and you will get a blowout.
To properly set the pressure, air up the tire to 32 psi. with the tire cold. on a nice straight, even, flat stretch of ground, take some chalk and throroughly mark a section of your tire.
drive the car for about 1,000 miles. check the wear pattern on the tire. adjust your psi as needed.
I drive extremely hard. my tires last only a short amount of time due to my behavior...but they wear evenly. I can replace the rears 2 times before the fronts ever need replacement.
1. Running less than 30 psi
2. High temperatures (ie: over 100F)
3. Crappy tire Quality assurance
#1 and 2 alone will kill a tire...the lack of QA was a huge factor.
drive forward for about 10 feet and check your chalk marks.
adjust your pressure and repeat....alternatively, you can do this with water...but the chalk is easier.even wear/removal of the chalk = a good contact patch
missing in the middle, but outer edges not touched = too much pressure
missing on the edges, middle not touched = too little pressure
Lol, I have had 20 tires on my car, 5 different sizes, 14 wheels. Only 37k on the clock.
Granted most of the tires were still ok and sold, like the OE's and snows.
235/50/18 BFG OE 4 on Fanblades
235/55/17 GY snows 4 on Bullits
255/45/18 GY summer 8 on Fanblades/CTR
285/40/18 GY summer 2 on CTR
275/40/17 GY drag radials 2 on FR500's
tire pressure needed will vary based on the size and type of the tire and the weight on the tire. there's no blanket rule that works for everything, ask anyone who does any real road racing. if it were as simple as reading the sticker on the car then race teams wouldn't spend time trying different setups.
there's some good reading in this article written by Michelin...
http://www.tirerack.com/tires/tirete...nd_Feeding.pdf
page 7 of the PDF they flat out say that for road racing that cold 25psi front and 28psi rear are good starting points and that you can go lower from there if you're hot pressure gets too high. 20 psi is their recommended minimum cold psi to keep from risking the bead unseating from the rim. that suggestion is based on the assumption that you're road racing the car with their sport cup tires and not at the drag strip.
Mickey Thompson suggests starting at 12psi on their drag radials in cars over 3,000 pounds, even less psi on larger tires...
http://www.mickeythompsontires.com/tech.php?bulletin=s3
there's a lot of variables, it comes down to the type of tire, the size, and the weight on the tire as to what pressure is "right". easiest way to tell what's "right" is to find a cold starting pressure that leads to even tread wear on the tire. whatever that number ends up being is "right" for your car and tire combination. someone else could run something different and still be right for their setup, again there's no magic number that always works, it's not that simple
however I'm hesitant to even suggest to anybody that they try anything under 30 psi for normal everyday driving. it's just a dangerous proposition
racing applications...yeah, different story.
