Steeda and Koni installed....
Old May 9, 2010 | 07:19 PM
Roy_R's Avatar
Roy_R
Default Steeda and Koni installed....
Finally had time to install the Koni's and the Steeda Sport springs. Also installed the Steeda HD Strut mounts...
Car is solid and the drive is perfect. I like the stance too, still has the Mustang aggressive look with the tail a bit higher.
Jack in position
Removing the torque bar
Securing the wheel assembly
Old strut assembly removed
Koni's installed
HD Strut Mounts, top side
Love the way it sits
Front wheel
Rear wheel
Old May 9, 2010 | 10:05 PM
Roy_R's Avatar
Roy_R
Koni Springs STR.T - Street (Orange):
http://www.stranoparts.com/
Steeda Sport Springs:
http://www.steeda.com/products/steed...springs_05.php
Steeda Heavy Duty Upper Strut Mounts:
http://www.steeda.com/products/heavy...nts_street.php
Not the best picture, but you get the idea....
Old May 10, 2010 | 02:08 AM
Chainsaw's Avatar
Chainsaw
Sweet man. How is the ride?
Old May 10, 2010 | 03:05 AM
Captain_Stangin''s Avatar
Captain_Stangin'
Lookin' good! I'll be putting a very similar setup on my Mustang, only difference is Koni Yellows and J&M camber plates.
Quick question: How do you adjust the camber once the plates are installed? Do you jack up the car and loosen the 4 bolts at the top of the strut, then just slide the top of the strut in and out until you reach the desired angle?
Old May 10, 2010 | 09:45 AM
crescent_wrench's Avatar
crescent_wrench
Looks great. Can't wait to do mine. Did you need an adjustable panhard bar to re-center rear?....or did it not shift much?
Old May 10, 2010 | 10:19 AM
Roy_R's Avatar
Roy_R
The springs are stiffer than OEM, but not so bad that your fillings fall out of your mouth. I did take it around a 90 degree corner at about 90mph, both front and rear tires got loose, but the power slide was very well balanced and controllable
PS. We have thank Sam Strano, he's the one who recommended this setup!
No need for the adjustable panhard bar...only required when you drop 2" or more I believe. Car is still centered. I didn't want it so low that speed bumps and parking lost become an issue.
Yep, sounds about right, must still have the alignment done.
Old May 10, 2010 | 11:27 AM
Norm Peterson's Avatar
Norm Peterson
Wish I could see the pics now, but work internet filters means that it'll have to wait until later. I have an upcoming task involving some Koni Sports that I only want to do once.
You can probably DIY the alignment, too.
Harbor Freight now sells a 16" digital angle finder that's good to 0.1° (it's about $25, IIRC from seeing it yesterday). Given a flat place to set up on, I think that anybody who can swap the struts and springs as a DIY project could put the camber where they wanted it (within the range that the strut mounts permit).
Keep in mind that toe will almost certainly end up getting changed a bit, partly from swapping in the new struts and partly from camber most likely ending up not quite where it was before the swap. Patience and parallel strings lets you fix this.
Norm
Old May 10, 2010 | 04:47 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
I'm glad you like it... but let me fix a few things for you... namely the links to the Steeda springs and HD mounts.
http://www.stranoparts.com/partdetai...D=75&ModelID=5
Old May 10, 2010 | 11:47 PM
Roy_R's Avatar
Roy_R
Nice Sam
As far as tools are concerned....had to use a 19mm socket on the strut compressing clamps.
Sockets 10mm, 13mm, 15mm and 18mm.
Socket Wrench
Torque Wrench (up 150lbs)
Wrench - 9mm, 18mm (9mm used to hold the top of the strut shaft)
Floor Jack
Jack Stands (x2)
PS. Not sure how to torque the bolt on the top of the strut. I used a shifting wrench on it, think it may be 20mm or 21mm.
Old May 11, 2010 | 12:08 AM
Kotobuki's Avatar
Kotobuki
The nut on the top of the strut is a 22mm. To torque it, I used a 22mm wrench to hold the nut, and put my torque wrench on the strut rod itself and torqued that to the appropriate torque setting. I don't know if that's sound... but it seemed right in my head. I'm sure an engineer will be able to correct me if I'm wrong. If I could find a 22mm Crowsfoot, I'd do it the right way.
