is this lower control arm kit anygood?
Was thinking about getting this..
http://www.summitracing.com/parts/UPI-103546-R/
I don't have first hand knowledge on these but have heard good things about UMI on many forums. This is the exact kit I plan to install in the next month or so. I have had contact with UMI via email, they were extremely responsive and helpful.
Let me know if you get them and how they perform, I will do the same if I get mine first.
BTW, they are a PA company...
The one issue is the none adjustable upper center link. If you lower the car you need to adjust that link to get the proper pinion angle. The Mustang suffers from drive shaft issues as is lowering it and not adjusting the angle will make it worse.
Also I have in the past run into problems with solid urethane bushings. I just recently found an answer to those problems in the suspension pieces from J&M. Yes they cost more but I am sure they will work better. I have ordered my they should be here any day. You should check them out.
Wow...1.625" od tubing! Those are some BIG control arms. (Typo, I'm sure)
As long as you don't plan on changing your ride height, they'll be fine, but if you plan on lowering your car you might consider some adjustability.
Edit...sorry for the repeat...908 beat me to it.
Solid urethane bushings will actually add some roll resistance, FWIW.
what about this 3rd link..says its for lowered cars
http://www.stranoparts.com/partdetai...D=99&ModelID=5
Also how do you set the pinion angle
Check out this upper link from J&M then checkout the rest of their line. Yes it more expensive. But the solid axle in a Mustang tilts from side to side those cheaper control arms fight this tilt. That is not the job of the control arm that is the job of the springs and sway bars. Hard urethane bushings work fine if all you do is go straight and want to stop flex in the rubber of the system but when you have bumps and corner to deal with they fight the suspension not allowing it to do the job it was designed for. That's why racers used steel spherical rod ends not urethane. J&M has invented a poly rod end it gives swivel freedom equivalent to the stock rubber bushings but eliminates the fore and aft moment like a spherical rod end.
http://www.hotpart.com/shop/index.ph...ct_detail&p=21
I guess I should also mention I dont race, never have and really never plan on going to a track strip or road course. I just like to mod and make it my own. So I guess I dont need the ultimate setup. Still how do you adjust pinion angle
An adjustable upper control arm is threaded and two pieces which by screwing it in or out you can increase or decrease the overall length of the arm. This arm connects the vehicle body to the top of the differential housing. Now if you imagine a longer arm will push the top of the differential towards the rear of the vehicle and a shorter one will pull it towards the front. This in turn rotates the entire rear end and axle which changes the angle at which the driveshaft and U-joint connect. I hope that made sense.
