UCA - not sure what to get
There's a nice StangTV how-to on 2-piece DS angle setting http://www.youtube.com/watch?v=i8FNgaNqS8s
It's tougher to do with a one-piece DS like mine. You basically have to get angles off of both end of the DS/flanges. And it seems not having it set perfectly with the one-piece causes bigger problems than the 2-piece shaft. Or at least the noises and vibration I hear from mine when it's not set perfectly leads me to believe that!
Just set it to stock length and install. You'll be ok.
I made a decision this morning. I liked the look of the UMI roto-joint/poly combo arm that I decided to just go ahead and replace my steeda poly/poly lower. This should theoretically provide for even more resistance to wheel hop issues over the current arms.
Additionally I got a set of UMI relocation brackets.
Between the new lowers plus the relocation brackets and the new upper mount and upper arm I have high hopes this is the last time I'm going to have to worry about wheel hop. At least until the bushings start to wear. lol
