help me pick an adj panhard
Let me preface this by saying I'm a MM dealer, as well as Steeda and UMI too.
I would not use an aluminum PHB. Having said that, PHB's are pretty simple devices and frankly it's hard to really mess one up provided the builder can actually weld and good parts are used.
UMI PHB's are, IMHO every bit as high quality as the others, and generally cost less (maybe being here in central PA and the lower overhead costs have something to do with that!). I would, and do recommend--and often use, UMI stuff to customers and on my own cars too.
My car had all poly bushings and the stiffer Panhard bar brace and KDW2s and it was the feeling described above, especially on a quck left to right chicane, that made me decide to buy the FAYS2 Watt's link. Since I have installed it everything just feels better and feeling better equates to going faster
If you are intending to track the car then save up until you can get the FAYS2.
Hi Sleeper_08,
I liked what the Watt's link did to the way the rear end of the Saleen PJ Edition car I test drove one day in the canyons around Mulholland Highway so much that I had to eat my hundreds of posted words and buy one. I was a Panhard fan for its light weight, simplicity and race track proven effectiveness against much more sophistcated multi-link IRS suspensions in the BMWs and Porsches the Mustangs were killing on the race track. But even the simplest S197 chassis Watt's links can work wonders for the way the rear end of the car behaves as was proven by my Saleen PJ test drive in the rough canyons off of Mulholland. The thing I like most about the Watt's link is the way turning left or right is now balanced in transition, the faster set and less side to side movement over real world freeway surfaces.
HTH!
Why don't you like the aluminum Panhard bar from MM? What material would you prefer the Panhard bar be made out of, the stiffest or something less rigid like mild steel used by UMI? Have you scaled the MM, Steeda and UMI bars? What do they scale at?
UMI Panhard bars are not any less money than either MM or Steeda PBs and at least on your website UMI has no double adjustable poly/poly Panhard bar in chrome-moly alloy steel which is the most popular configuration on the street.
Cheers!
I really don't get you F1Fan (I'd still like to know exactly who you are). I think you like to argue just for the sake of arguing with me.
Why don't I "like" aluminum PHB's? Simple: Because I've bent aluminum PHB's in use on autox cars.
I don't know how you figure that they are the same price. A Steeda double poly bushed adjustable PHB is $159, a UMI double poly bushed PHB is $118.... and that's for an On-car adjustable one (read easier and quicker to setup). In fact a UMI dual Roto-joint PHB is $153.99 and that's less than the Steeda urethane PHB.
There is no reason to have a double adjustable PHB w/urethane. The adjustment is for length. The PHB doesn't care if that happens at one location or two. The reason the bigger bars with rod-ends or Roto's are "double adjustable" is because those parts screw in anyway, giving you "double adjustment".
UMI does offer CM in the higher, more race type bar as an option. Frankly it's not worth much vs. mild steel in tension or compression which is the mode the PHB operates. In fact CM is used in thinner wall to match the strength of mild, but with less weight. Just because a bar is CM doesn't mean it's automatically stiffer any more than have a V-8 means you have more power than a cylinder. What if that 4 banger is an Evo?
Bottom line, depends on wall thickness. And if you are running urethane bushings the deflection in those is much greater than the difference between a mild steel vs. CM PHB.
But either a PHB or a WL defines one of the points on the axle roll steer line. The other point is the intersection of the LCAs, which is 20-odd feet out behind the axle and something like 20" above the ground in the S197 case. The amount of roll steer is more sensitive to LCA inclination than it is to an equal amount of PHB/WL height adjustment, but that's not quite the same thing as saying the PHB/WL has no influence at all.
Sort of the flip side here is that LCA inclination has a very small effect on your rear roll center height. Not enough to matter in most cases, but since the roll center is where the roll steer line crosses the axle line, anything that affects its slope also moves the RC.
It may be convenient in many situations to consider that RCH is defined by the PHB or WL and that roll steer is an LCA inclination effect, as long as it is kept in mind that these are only approximations and not geometric absolutes.
Something to ponder . . . the rate of roll steer does not remain constant over suspension travel, and will change at slightly different rates for a PHB, an axle-pivoted WL, and a chassis-pivoted WL even if they start out with the same roll center heights with the car at rest.
Norm
Hi Sleeper_08,
HTH!
HTH!
In Ontario if we get caught "Street Racing" they can impound your car for a week on the spot, suspend your licence for a week and can fine you up to $10,000. And you can imagine what that does to your insurance rates!
http://www.mto.gov.on.ca/english/about/bill203.shtml
Your experience is the same as mine except mine is on the track.
Sleeper,
I think that a smoother surface and more steady state cornering is why the S197's Panhard bar is less an issue than on a bumpy surface. It seems to me the differences are felt more easily where the suspension is busy moving closer to its extremes and the chassis is upset more of the time. But I agree with you and if I had it to do over I might look at the Steeda or Fayes2 Watt's links. I think I'd like to be able to play with the rear roll center height of the car which I cannot do with the simpler Saleen Watt's link. But I one thing I gotta say about the Saleen PJ Watt's link is that you never know it's there. I mean it is very simple, lightweight, dead quiet and smooth. So far I have not heard a peep out of the thing but I'm almost ready to put the car up on stands to do my semi-annual suspension teardown, cleaning, inspection and lube. I gotta get the M3 out of the garage first though. I'm still waiting on my TCKline Racing D/A coilovers to come back from the Koni West shop after a rebuild and a few million bucks in parts to finish trickling in before I can bolt it all back together then bolt it into the chassis. It's getting close though!
Well I think we have the same issue but folks don't really race per se any more. Back in the 60's and early 70's there was some real racing going on there and there were some epic police pursuits that happened too. Pretty crazy stuff but I just managed to miss the best of it as I was too young to drive at the time. I did get arrested for speeding once (clocked at 147mph on Muholland Highway) and they did impound my bike but things were different back in the 70's and I plead to two lesser charges and got my bike back for the towing charges. I only get out to race track once in a while for club events but not as often as I go to the canyons to clear my head.
Cheers!
Last edited by F1Fan; Jul 16, 2010 at 01:38 AM. Reason: opps, pressed the wrong button
