help me pick an adj panhard
Old Aug 23, 2010 | 07:47 PM
  #31
perfect storm's Avatar
perfect storm
Personally like BMR PHB
Old Aug 23, 2010 | 08:37 PM
  #32
F1Fan's Avatar
F1Fan
Really? Why?
Old Aug 24, 2010 | 10:50 AM
  #33
Sam Strano's Avatar
Sam Strano
Former Sponsor
Because we've bent them. That's why I don't like aluminum PHB's (or LCA's for that matter). But the PHB is way too long and already prone to flex. Aluminum is just more prone to it and we bent one on an SN95 (and no it wasn't jacked up upon), and I've seen a number of others bent as well, but I can't say if in every case they weren't hit with a jack.
As for the type of PHB: I have CM bars too, and in fact one of the bars I see is the Steeda bar. Once you have poly bushings at each end, that's the weakest point, not the material. If you are building an all out race car, then sure--go CM but at that point you'd also not opt for urethane bushings, but rod-ends or roto-joints.
And CM is not automatically lighter, it's no lighter than mild steel. The only way a CM part is lighter is if they use a thinner wall tube because it's CM, which puts you back to the same strength as mild. And the difference on a PHB isn't even 1 pound in most cases. The entire PHB is only about 7 pounds in total!
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
mdg
Oct 1, 2015 07:04 AM
