Tire caused handeling problem
Old Aug 11, 2010 | 02:20 PM
utmustang07's Avatar
utmustang07
Default Tire caused handeling problem
Hi all,
I just purchased rear tires for my 07GT and noticed at speeds from 50MPH to 80MPH that the car tends to wander. The rear tries are slightly larger then the front and I suspect that to be the issue. My question is what can be done to eliminate this wandering. My front tires are 235/45ZR17 my rear are 245/45ZR17. Any help would be great.
Thaks,
Dave
Old Aug 11, 2010 | 03:50 PM
parchisi's Avatar
parchisi
I, as well as lots of other people have had larger rear tires without a problem, so I can't really imagine that being the issue. When was the last time you had the alignment checked?
Old Aug 11, 2010 | 03:58 PM
Derf00's Avatar
Derf00
Gentleman's Relish
wandering could be as simple as improper tire pressure. What pressure do you run your tires on?
Old Aug 13, 2010 | 11:06 AM
utmustang07
I have never had it aligned. Howevere I did not have this issue untill the rear tires were replaced. It was like flipping a switch and since nothing was done to the front end at the time.
As far as the new tires I have not checked it since they were put on. I used to run the old tires at 35lb. What would be a good pressure?
Old Aug 17, 2010 | 11:58 AM
utmustang07
Hi,
Thanks for your response. I checked tire pessure and it is at 35lb all around. I also had my alignment check yesterday and was told it was fine. The shop that checked it said it could be the front tires however these are the tires I have had all along the only thing that I changed was the rear tires. Any ideas?
Dave
djbigskrilla
Sep 20, 2022 01:04 AM
67STANGX2
Dec 28, 2015 12:17 PM
CarrieS
Sep 1, 2015 01:00 PM
DrunknRuckus
Aug 23, 2015 10:05 AM
HIS S-197
Aug 10, 2015 05:47 PM
