Need Alignment Help ASAP!
Old Oct 5, 2010 | 11:33 PM
Unleashedbeast's Avatar
Unleashedbeast
Here are some more tidbits of information I gained by working with my alignment tech.
When I was running OEM upper strut mounts and camber bolts:
The maximum adjustment of positive gain from the camber bolts (and adjusting the strut mounts as far towards the outside of the car as possible) resulted in a near zero degree negative camber.
Now that I'm running Steeda HD camber mounts (adjusted to max positive gain - towards outside of car):
The maximum positive gain resulted in negative camber of -0.5* on the right and -0.7* on the left.
I also want to add that he did have to re-adjust my toe in after this little of change in negative camber. The car didn't feel right after the swap until he fixed it. Hard to believe so little makes a difference.
Adjust your camber bolts to the maximum positive position (the top of the spindle is leaning away from the car) and you will have a near zero camber. This with a good setting on toe in will insure your tires do not wear like that any more.
Old Oct 7, 2010 | 08:59 AM
fasterplease's Avatar
fasterplease
Good info...a couple of questions:
Is toe adjustable with stock components?
What didn't feel right before the toe was adjusted?
Old Oct 7, 2010 | 09:59 AM
chrumck's Avatar
chrumck
Toe is the ONLY adjustable thing with stock components.
Old Oct 8, 2010 | 04:41 PM
ffk_pennywise's Avatar
ffk_pennywise
So I went to the shop this morning. They took the car and a bit later the tech came and got me. He said he'd be happy to realign my car after I replace the lower ball joints. Ugh. He showed me that they were sloppy. The cars closing in on 90k miles so I guess its time. Looks like I have another item for my checklist this weekend. In the past 3 weeks I've had the following kick me in the nuts: New battery for the GT, new battery for my wifes Aspen, crap alignment trash my tires, and now ball joints. Life - 4, Me - 0.
Old Oct 9, 2010 | 02:09 AM
Unleashedbeast
The car felt like the steering wasn't precise, and it wanted to wander. It really didn't want to remain straight on a perfectly flat, no crown highway.
Old Oct 12, 2010 | 10:34 AM
ffk_pennywise
Got the ball joints in this weekend, and my alignment completed this morning. Whew! Hopefully thats all the maintenance this car will require for a while. Those ball joints sucked the life out of me.
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
