Over-Torque
Old Nov 6, 2010 | 11:31 AM
moochman4life's Avatar
moochman4life
Default Over-Torque
Ok guys, hypothetical question: What could potentially happen if someone over-torqued their rear-shocks during install? I'm talking top and bottom, here. Say...if one didn't have a torque wrench, so they cranked on the wrench until it was "tight"?
Last edited by moochman4life; Nov 6, 2010 at 11:32 AM. Reason: removed a "?" and added a "."
Old Nov 6, 2010 | 11:45 AM
157dB's Avatar
157dB
Cut & Paste Expert
Um, the one-time-use fastners could break at the worst possable moment.
Over-torquing them is actually worse than undertorquing them
and using some blue LocTite...
Next question...
Old Nov 6, 2010 | 11:55 AM
moochman4life
See, I learn something every time I post a question here. *.pdf saved and added to my toolbox.
So, that aside (say, they are not a concern), would there be any detrimental affects to driveability?
Old Nov 6, 2010 | 02:43 PM
157dB's Avatar
157dB
Cut & Paste Expert
Um, one shock on one side and non-on the other
transition at high speeds into a corner (when its
most likely to break) and the rear end lean could
throw you into the ditch or oncomming traffic...
Oh, I see the question now...
No detrimental effects. Other than the one above. (not a concern)
The top shock mount might not like being overtorqued
but the lower mount has a steel spacer sleeve that
would probably handle the increased torque value
all the way up to the point of fastner failure.
solidGas
Aug 9, 2021 07:43 PM
joshetc
May 5, 2012 08:47 PM
HamMach1
Apr 12, 2008 10:38 PM
Apr 6, 2008 05:32 PM
