brake pad rubbing
I have the Baer Extreme Plus kit and had to replace the front rotors. I took the calipers off and hung them with bungee cords so I didnt have to take the brake lines off. I installed the new rotors but now the pads slightly rub on the rotors. It's not hard to turn the wheel but if I rotate the wheel it stops before it makes a whole turn. Will this self correct after I drive it a bit or do I need to bleed them a bit?
Your pads will always rest on the rotors when the pistons are extended. You shouldn't be able to spin the front wheel freely...there should be a small amount of friction. It sounds fine to me...drive it.
Why did you have to replace your rotors?
I replaced them because believe it or not they were slightly warped. They are two piece rotors so I kept the hats and replaced the rotors. Yes I compressed the pistons by using two C-clamps and pushing the pistons back in. They wouldnt fit on before trying this. I was able to get them on but there is a slight rub.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sep 25, 2015 06:42 PM
