What do I need strut mounts?
Old Apr 2, 2011 | 11:06 AM
1984 anniv's Avatar
1984 anniv
Default What do I need strut mounts?
I have a 2011 v6 base. I know when replacing the front strut mounts I need 2005-2010 versions. I was looking at the gt500 models but also thinking about just getting the steeda hd mounts. In order for the steed mounts to work do I have to by the whole gt500 mounts too? Can I buy just the ford part I need without the whole mount?
Old Apr 2, 2011 | 11:34 AM
JAJ's Avatar
JAJ
You didn't say why you're replacing the front strut mounts, but if you must for some reason (as opposed to just using what you have) then you have two alternatives:
1. buy OEM Ford mounts and use them as they are (the FRPP GT500 ones for instance), or
2. buy the Steeda's plus a set of OEM mounts because the Steeda's need the rubber isolators off the OEM mounts.
The Ford parts website does not show the rubber isolator as being available separately, so a dealer could tell you for sure, but it looks to me like you're going to have to buy OEM 2010 mounts in either case.
Old Apr 2, 2011 | 11:40 AM
6-Speed's Avatar
6-Speed
Or you can just remove and re-use the rubber isolator from your current strut mounts on the Steeda parts.
Old Apr 2, 2011 | 01:07 PM
1984 anniv's Avatar
1984 anniv
I'm going to buy a se of the koni str.t shocks and a set of steeda sport springs so I want to make sure I have the right parts before I start . I'll check with the dealer too see if the spring piece can be bought separate if not I may try just the gt500 mounts since it's just a street car primarily
Old Apr 2, 2011 | 02:21 PM
parchisi's Avatar
parchisi
I think you do need to use 2010 and earlier isolators. The rubber isolator is different on the 2011's and won't fit with the Steeda mounts.
2011 on left, 2010 on right.
And yes, when I did it, I had to buy two whole mount assemblies to get those spacers. Either that, try a salvage yard or online.
Old Apr 2, 2011 | 02:54 PM
1984 anniv's Avatar
1984 anniv
Thanks. It appears people are getting that popping noise from both mounts so I'll try the gt500 ones first. It's a street car that may see a few autocross events just for fun.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
