Which panhard bar?
PHR006 is the BMR panhard bar you want. I just installed another one 2 weeks ago, very nice bar, very easy to install.
As far as the springs, I would "assume" there are different versions because of the weight differences of the cars.
Nowhere did I ever say that they are loud. You hear a bit more axle whine but that is all. I run a full rod ended PHB and pol/rod LCA's and my rear end is in no way "loud". Does it make more noise then stock, yes, but then agian so does your exaust.
AT times means when you go ever say a speed bump. You will hear it but other than that i got nothin.
I'll send you a PM when I'm ready to install, so we can work something out.
+1 Cameron. I love mine, it never makes any noise. Make sure you put some blue lock-tight on the lock nuts though cause otherwise there is a good chance they will vibrate loose.
