Front strut spring install question
Old Jun 4, 2011 | 07:39 PM
1984 anniv's Avatar
1984 anniv
Default Front strut spring install question
Other than the rubber sleeve at the bottom of the factory spring is there anything else that is swapped over to the spring and strut when installing new ones? Can you buy the sleeve by itself from the dealer. I' d rather have the new spring and strut assembled prior to removing the factory stuff in case I have a. Issue with the install. I installed the rear springs shocks and front and rear sway bars no issue however fronts are a bit harder.
Old Jun 4, 2011 | 07:52 PM
1984 anniv's Avatar
1984 anniv
Sorry forgot to mention I have the gt500 mounts so the old mounts won't be needed
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
inyadreems
Aug 21, 2015 09:10 AM
01moostanggt
Aug 17, 2015 01:22 PM
