STR.T struts and shocks are installed...and now my camber is -1.6?
Old Nov 22, 2011 | 12:06 PM
  #21
Sam Strano's Avatar
Sam Strano
Former Sponsor
That's mostly due to the Shelby GT's having been lowered 1.5" from the OEM springs.... It is easier and cheaper to just "tweak" the range around the spec than to put money into the cars to give them adjustment to set them back to around -.8.
Old May 30, 2013 | 05:01 PM
  #22
STANGmole's Avatar
STANGmole
Flash forward...15k miles later and my tires are nearly bald on the inside tread
Any suggestions for a reasonable negative camber? I'm thinking of having them set it at -1 degree after I buy camber bolts from Strano.
Old Jun 3, 2013 | 06:08 PM
  #23
Sam Strano's Avatar
Sam Strano
Former Sponsor
Assuming you can trust the racks and the toe wasn't all jacked up (I'd just run zero for minimum scrub), you just don't drive the car hard enough in corners to need or want much negative camber, and should set it back to a more stock like setting.
Old Jun 5, 2013 | 12:33 PM
  #24
jpplaw's Avatar
jpplaw
In order of expense, high to low:
Camber plates, or
Camber bolts, or
Undo the four strut mount bolts, drop the strut down and turn the mount the exact opposite of what it is now, then bolt it up again. You can gain up to .75 positive camber that way.
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
